Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat > '97+
Old 02-04-2006, 12:22 AM   #1
brucemyles
Back door window
When I try to close the window on the drivers side back door the window goes up and then come back down again and on the second try it stayes up.
Can someone please help.
Thank you
brucemyles is offline   Reply With Quote
Old 02-05-2006, 10:32 PM   #2
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
Re: Back door window
sounds like the windor motor is bad. it has load sensor in it
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Old 02-08-2006, 02:18 PM   #3
brucemyles
I removed the door pamel and the plastic part that carries the window up and down is broken on one side,could that be causing my problem
Thank you for the reploy
Old 02-08-2006, 07:09 PM   #4
veedubmechanic
VDUBMAN
yea. if something is broken, replace it. the load sensor in the motor is problably picking up the window jamming on the broken piece
Old 02-10-2006, 11:52 PM   #5
brucemyles
Thank you for the reply and I will try that.
