Go Back   Automotive Forums .com Car Chat > Honda > Legend | RL
Old 05-29-2005, 02:57 PM   #1
CR50HC
97 RL Ride quality
Hi folks. My first post on the RL forum. My wife just bought a 97 Acura RL. To me, the suspension feely really bouncy especially in the rear. You can feel every bump in the car and it doesn't handle the greatest. The car has 94,000 miles on it. I suspect the struts? Any thuoghts? What are the most cost effective options?
CR50HC is offline   Reply With Quote
Old 05-30-2005, 09:28 PM   #2
CR50HC
Re: 97 RL Ride quality
Anyone?
Old 06-05-2005, 10:07 AM   #3
CR50HC
Thanks for all the support...
Old 11-02-2005, 05:34 PM   #4
esco3002
high miles for acura?
looking at '98 RL with 145,000 miles is that a lot for an Acura????
esco3002 is offline   Reply With Quote
Old 02-02-2006, 01:16 PM   #5
pghsold
Re: high miles for acura?
No...I have a friend with over 300k on his. Just maintain it and replace timing chain/tensioner/water pump at specified intervals.
pghsold is offline   Reply With Quote
Old 02-04-2006, 04:55 PM   #6
Privatebigandrew
Privatebigandrew's Avatar
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
If it is bouncing around like you say, then i say its the shocks. The aren't able to dampen the up and down momentum from the springs. Look at them and see if they are leaking any fluid. If so, they are definatley blown and need replacing. But just some info. The older RL's like yours are very sloppy feeling even when they were brand new. Its just a characteristic of the car. I call it the grandma feel.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Privatebigandrew is offline   Reply With Quote
