Old 06-11-2002, 10:33 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Car not wanting to start sometimes...
OK yesterday and about 2 other times in the past 3 weeks my car has cranked but didn't want to start, both time were when the engine was still warm. I can eventually get the car to start after it sits a minute though...
Ok I know it is not...
Battery (only 4 months old)
Starter (only 3 months old)
Spark Plugs (4 months old)
Spark Plug Wires (3 months old)
Distributor (I know it spins, I can still drive the car)
Fuel Pump (Car will still run)
That's my knowledge of what goes into my car starting. Other than those what could be possibly dying?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-11-2002, 10:38 AM
darolh darolh is offline
Coil?
They sometimes suffer form heat although the normal scenario is the car crapping out and you have to wait for it to cool down to run again.
Old 06-11-2002, 10:47 AM
Is the Coil that black cylindrical thing in the back towards the fire wall?
Is it possible maybe it's old and dying?
Old 06-11-2002, 11:53 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
no, the coil is in the distrbuter in our cars... its the lil square box type thing... well, when it does it check and make sure you are getting spark, if you are then its not the coil or anything like that... i know from experience when my car did something like that it was b/c my headgasket went then my car overheated and my head had a lil warpage... right before it finally died that what it'd do... i'm not saying thats you prob... but it could be
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 06-11-2002, 12:10 PM
Not the distributor seems to work fine. And my car has started first thing all day so far so I don't know....
Old 06-11-2002, 12:37 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
are you getting any check engine lights coming on?
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-11-2002, 01:18 PM
daddys's Avatar
daddys daddys is offline
i had that same problem a while back,,a bunch of guys on the board told me it was my main relay and someone sent me this page,,, http://autorepair.about.com/library/.../aa010301a.htm
i changed two things,,,my main relay wich you can get at a dealer and my oxygen sensor and i never had taht problem again
hopefully that is your problem
Old 06-11-2002, 07:19 PM
Shadowkahn Shadowkahn is offline
Send a message via ICQ to Shadowkahn Send a message via AIM to Shadowkahn
yeah, that really does sound like the main relay. The solder joins in that thing weren't very good and will break. Then when it gets hot, the contacts will pull away and it'll kill the start.
The MR is located behind the coin box. Remove the coin box and gently bend the dash outward until you can unscrew the mounting screws. Then remove the MR, unplug, and reinstall in reverse.
It's around 60 bucks or so for a genuine honda part (they're made better now).
www.hondaautomotiveparts.com has the best prices.
Old 06-11-2002, 07:46 PM
88ReX 88ReX is offline
it could be the main relay or it could be something else....I had ur exact same problem but I was throwing a code 13(injector).....you need to check ur ecu so u dont waste money on something you dont have to
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 06-11-2002, 09:35 PM
No check engine light came on so I assume it wouldn't be throwing any codes.
Old 06-12-2002, 02:16 AM
might as well check tho.....its easy to do
Old 06-12-2002, 05:03 PM
Ok this pos did it again today. I had to sit in the car for like 15 minutes trying it. Finally I decided to take out the coin thing and I pulled the Relay out and inspected it. I blew on it incase it was too hot or something then I plugged it back in and I got the car to start. So I'm sure it is this.
And will my car throw codes if the engine light is not on. And if it is throwing a code how do I check it?
Old 06-12-2002, 05:10 PM
"If the main relay is bad... on a Civic, you will lose power to the injectors and the fuel pump but you may not lose fuel pressure because the injectors can't open without power. When the main relay goes bad and there isn't any voltage at the injectors, it will set a code 16 for an injector because the computer doesn't read voltage on the groundside of the injector.When the main relay goes bad and there isn't any voltage at the injectors, it will set a code 16 for an injector because the computer doesn't read voltage on the groundside of the injector."
http://autorepair.about.com/library/.../aa010301b.htm
Old 06-12-2002, 07:12 PM
ur right it is code 16, I did however clean my injectors and reset the ecu, havent had that problem since
I think the engine light will come on if U have a code, however if it starts up fine it will still keep that code in the memory if the engine light came on at some point in time and the ecu hasnt been reset. Its worth it to check it out:
All the information below was sourced from http://www.quickhonda.net/index2.htm
1988-1991 HONDA CRX
The ECU is located at the front of the passenger footwell, under the carpet. There is a single flashing light in the center of the ECU that flashes the codes. Simply count the flashes in each sequence to determine the code:
Code 0______Faulty ECU
Code 1______Oxygen content
Code 2______Does not appear to exist
Code 3______MAP sensor
Code 4______Crank angle sensor
Code 5______MAP sensor again
Code 6______Coolant temperature
Code 7______Throttle angle
Code 8______Top dead center sensor
Code 9______No. 1 cylinder position(only on 1.6L)
Code 10_____Intake air temperature
Code 11_____Does not appear to exist
Code 12_____Exhaust gas recirculation system
Code 13_____Atmosphric Pressure
Code 14_____Electronic air control (EACV)
Code 15_____Ignition output signal
Code 16_____Fuel injector
Code 17_____Vehicle speed sensor
Code 18_____Does not appear to exist
Code 19_____Lock up control solenoid (auto trans only)
Code 20_____Electric load
The ecu is jsut under the passeneger side carpet, just lift it up and U will see the ecu, there is a light in the middle (very small) that will blink if you have a code. Note: the car doesnt have to be on for the code to display simply the ignition must be on
Old 06-19-2002, 12:30 PM
Oh brilliant. My car just did it two days ago. Stalled right after I started it up (warm) and then was snotty about starting until it finally did. I thought I'd lost the timing belt for a second there. I'll watch out for that relay thing. Good info everybody.
Winstar will not start sometimes bwagner61 Windstar 5 02-21-2010 02:04 PM
What would cause my car not to start when it's raining?? Is it electrical? or other? tanyaa7574 '88 - '91 Civic | CRX | Wagon | Shuttlee 20 11-16-2007 12:06 AM
Car will only start sometimes Please Help!! aj95023 Cavalier Problem Diagnosis 3 03-14-2005 06:19 PM
