Go Back   Automotive Forums .com Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-25-2006, 06:11 PM   #1
mazdamagee1
B2200 Gauge cluster swap to Tachometer unit
I have an '89 B2200 with the basic gauge cluster and picked up a '87 B2000 parts truck that has a tachometer in it. The swap was easy, but I found that the digital clock does not work in my truck. Does anyone know what I could do to get it working in my truck? I know it works in the parts truck! Can I just run power to a connection point?
Any ideas would be much appreciated.
mazdamagee1 is offline   Reply With Quote
Old 01-28-2006, 04:50 PM   #2
Kyrasis6
Kyrasis6's Avatar
Send a message via AIM to Kyrasis6
Re: B2200 Gauge cluster swap to Tachometer unit
Wiring for the clock should already be in the dash somewhere. I don't know if the clock has a memory wire or not or if it has an internal battery to hold memory. I would clip it to the battery and set the time then unplug it and see if it holds time, if so just wire it to accessory power.
Owner of Mazdatruckin.com
Kyrasis6 is offline   Reply With Quote
Old 02-07-2006, 08:35 PM   #3
MAZTANG
i had one put it in my truck and it worked fine i unno maybe u got a wire coroded off sumwhere...iv got a 91 b2200 and i got a parts truck with the tach clock and all the good stuff in it and the clock worked fine...held time and everything
MAZTANG is offline   Reply With Quote
