Old 01-09-2006, 01:45 PM
LinkCRX LinkCRX is offline
91 CRX Overheat
My 91 CRX HF's been overheatin rather quickly lately. Even 10 min rides it would over heat. Initially I thought it was lack of water in radiator. Flushed that and Re-sealed it just incase there was a leak. I Changed the oil in it thinkin that'd help but no... still over heating rather quickly.
Any answers or suggestions would be MUCH appreciated.
The Temperature gauge would be fine for a few mins.... at medium. Then within seconds it'd JET up within the red (literally) and sometimes! just sometimes it'd shoot back down to medium just as fast as it shot up. But..... its over heating none the less.
No theres no leaks.
Yes theres fluid in radiator.
Oils been changed.
Old 01-09-2006, 03:44 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: 91 CRX Overheat
Is the fan coming on?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-09-2006, 04:23 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Re: 91 CRX Overheat
my car did that for about half an hour, until i got home. i replaced the thermostat and everything was fine, but be careful because overheating is really bad on your motor
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 01-09-2006, 09:40 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
Re: 91 CRX Overheat
that happened to me. i took out the thermostat and it went away.
Old 01-09-2006, 09:50 PM
Hybrid1990crx's Avatar
Hybrid1990crx Hybrid1990crx is offline
Send a message via AIM to Hybrid1990crx
Re: 91 CRX Overheat
you know its bad to run your car without a thermostat.
Saturn Stealership Technician #331
Old 01-10-2006, 12:24 AM
Re: 91 CRX Overheat
I appreciate the help fellas. Might be a newb question but taking out the thermastat.... wouldnt that just mean I wouldnt know of the engine is over heating or not? Instead of knowing its overheating.
Old 01-10-2006, 01:21 AM
bionictony's Avatar
Re: 91 CRX Overheat
is it really that bad? it takes the car a bit longer to warm up. i thought it was ok in so cal weather. i've been thermostatless for almost 2 years.
Old 01-10-2006, 01:31 AM
Re: 91 CRX Overheat
"is it really that bad? it takes the car a bit longer to warm up."
Lmfao.... unfortunately yes.... Hmmmm Is it difficult to take out the thermastat?
Old 01-10-2006, 09:13 AM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
Re: Re: 91 CRX Overheat
Just need to take off 2 bolts and then remove the old termostat ....but drain the coolent first
Old 01-10-2006, 09:14 AM
Deadboy's Avatar
Just need to remove 2 bolts and then remove the old termostat ....but drain the coolent first
Old 01-10-2006, 11:55 AM
Re: 91 CRX Overheat
its bad because it makes your car run cold, and a cold running engine is not a happy motor, it stays in the cold enrichment loop and uses more gas, runs rich, and it can cause a shitty idle and many other problems. having no thermostat CAN acutally cause your car to overheat because the coolant flows so fast it doesnt have time to transfer to heat to the radiator.
Old 01-10-2006, 12:26 PM
Re: 91 CRX Overheat
Thanks guys... hopefully that'll fix it. Thanks a bunch. Drinks are on me tonight.
Old 01-10-2006, 12:33 PM
fierangero's Avatar
Re: 91 CRX Overheat
the thermostat is on the back of the motor, not on the front like most cars, found that out the hard way haha. the book says to disconnect the heater hoses but you dont have to unless you want to take out the whole housing...
She's done!
Old 01-10-2006, 01:23 PM
4thgenSIR 4thgenSIR is offline
Re: 91 CRX Overheat
Also make sure you loosen the bleeder screw when you put coolant in. I've seen cars that overheat badly just because there was an air pocket.
Old 01-10-2006, 08:23 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: 91 CRX Overheat
or head gasket.
