Does anyone know if a rebuilt kit for a 95 buick lasabre would fit a 96 buick lasabre?
My buick has a blown head gasket and i think i have 2 rebuild the engine but i can't anywhere with a 96 rebuild kit. Does anyone know where i could find one at a reasonable price? Or maybe there is a way i could fix the blown head gasket, if thats what it is, without rebuilding the entire engine. Any help would be appreciated. Like if findin coolant in da oil and it blowin white smoke means its a blown head gasket. And is there a way i can diagnose it without takin the engine apart, i don't have a scanner.
(\__/) (='.'=) This is the original Bunny. Copy and paste bunny (")_(") into your signature to help him gain world domination *1987 Oldsmobile Ninety-Eight Regency Brougham.* (deceased) *2003 Ford Mustang GT* just a CAI and Exhaust...for now
Re: 95 fit a 96?
Could be the troublesome upper intake at the egr passage the signs are evident whe you pull the upper intake off look for leakage and deterioration at the egr passage. More common than head gaskets.
Re: Re: 95 fit a 96?
Thanks for the advice. Hopefully thats the problem and I wont have to reubuild the engine.
Is there somewhere I can get a walkthrough for pulling of the upper intake. I dont want to mess up anything that isn't already broken.
Re: Re: Re: 95 fit a 96?
If you're contemplating doing this you should
- get a Haynes Manual - stop using profanities - find all you need to know at this link http://www.autozone.com/servlet/UiBr...rGuideYMMEYear |
Re: Re: Re: Re: 95 fit a 96?
Re: 95 fit a 96?
The 95 engine in the LeSabre (if that is what you have) is series I. The 96 is series II. Parts interchangeability is insignificant between the two, so a rebuild kit made for one wouldn't work in the other.
Re: 95 fit a 96?
You could do a pressure test on both the intake and the head gasket to narrow down what's realy wrong! When you do the intake remove the intake hose at the TB (throttle body) and remove the defuser on the TB (screen at the intake),pressurize the system and listen and look into the TB while holding the throttle open,If all is good then pull the plugs and see if fluid comes out there,that would be more of a head gasket or other problems ,good luck
Re: 95 fit a 96?
