Go Back   Automotive Forums Car Chat > Ford > Escort
Old 10-29-2005, 03:54 PM
shaff408 shaff408 is offline
Strange noise when coasting...
My '99 Escort ZX2 is making a strange noise. When at low speeds, and coasting, there is a noise/vibration that comes from the front wheel axle area. It's almost like you can feel the turning of the axle. Is this a transmission problem?
Old 10-29-2005, 08:05 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Have you checked the fluid level in the tranny?
Nevada Tumbleweed
Old 10-29-2005, 08:10 PM
I just had the transmission fluid changed about a month ago.
Old 10-30-2005, 05:53 AM
All the more reason to check it.
Nevada Tumbleweed
Old 12-08-2005, 05:54 AM
sk8er4trix sk8er4trix is offline
this would be your ball joint is loose. wich is from havin a loose tie rod
you can easily replace yourself, tierod and balljoint will run you bout
$80, jack up yer car shake each tire and find wich one is loose.
then go get the part n replace, this was my problem. before you buy the parts. when yer car is jacked up make sure your struts are tightly bolted to your mounts. loose struts will also make a noise but usually all the time and not just when coasting.
