Old 12-05-2005, 09:33 AM   #1
btony
93 Lunina Won't Start
At first the car would not start some times. It would turn it over, it sounded like it was not sparking at all. The stange thing is that if I let the car sit for a few hours it would start up right away. I could then drive it with not problems.
I changed the spark plugs and plug wires to make sure that was not a problem, it was time for a tune up anyway. I could see that all of the plugs had been firing well. None of them looked fowled.
After changing the plugs and wires the car would not start again. Note I was careful to get the plug wires on in the same order, changing them out one at a time. We tried several times, and again it sounded like it was not firing at all. Not even trying to start.
We reset the computer module by disconnecting the positive batery cable for a few minutes. When we connected it again and tried to start it again it started, ran for about 2 seconds and died again. After stalling it would not start (Same thing as before). We repeated disconnecting the battery 2 more times, and each time it did the same thing.
If anyone has any suggestions of things to try I would appreciate the info.
btony is offline   Reply With Quote
Old 12-05-2005, 09:52 AM   #2
maxwedge
A990 racer
Re: 93 Lunina Won't Start
Any diagnostics going on here?? Do you have good spark?, If you spray carb cleaner into the intake will it keep running?, What is the fuel pressure at the rail?
