Go Back   Automotive Forums Car Chat > Subaru > SVX
Old 04-12-2002, 07:53 AM
VH45DETTwithNOS VH45DETTwithNOS is offline
Manuel for a 95 SVX
Hey which Gear box will bolt into a SVX, I need to know because well the Auto kinda gave up...................
If no other can be found then I'll try my age ol' trick, Holianger...
Enemy - show me what you wanna be
I can handle anything
even if I can't handle you
Readily - either way it better be
Don't you fuckin' pity me
get up, get off.........
Slipknot - (SIC)
Old 06-23-2004, 06:26 PM
UnlimitedEK9's Avatar
UnlimitedEK9 UnlimitedEK9 is offline
Send a message via AIM to UnlimitedEK9
Re: Manuel for a 95 SVX
92 Legecy
UnlimitedEK9
MUGEN-POWER
SPOON SPORTS
Hold On Not Done Accelerating
Old 03-09-2008, 12:49 PM
paparicky paparicky is offline
The 92-98 Subaru 5-speed gearboxes excluding Loyale and, God forbid, Justy- will bolt up to the engine. The '99 and later trannys use an 8-bolt engine mount so they will not work. You will need to fabricate the tranny mount and add a different drive shaft, as the transmissions are a different length. Just any transmission will not do, you really want the '98 WRX tranny at is it fully capable of handling 300HP. The '93-'94 Legacy Turbo tranny is also a candidate, but is not as strong. The '98 Impreza 2.5 RS might also do the job. All of these are $3500 to $4500 new. You also need to fabricate a hydraulic clutch setup and shift linkage. You also need to change the rear gear to suit the transmission (none listed use 3.54).
Old 03-10-2008, 01:07 AM
cheers man, it's a old project one of 4 now....
Slipknot - (SIC)
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
PLEASE HELP- Don't have manuel for 03 Cavalier... Melb84 Cavalier 1 02-27-2007 10:11 PM
FS Chilton's Manuel for the 1st Gen ned032002 Classifieds 2 07-10-2006 10:19 PM
need wiring diagram/ workshop manuel for '93 Mirage Cyborg R John Lorimer Mirage 0 10-29-2005 05:21 AM
