Go Back   Automotive Forums .com Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 11-03-2005, 08:05 PM   #1
HondaCivic4358
HondaCivic4358's Avatar
Send a message via AIM to HondaCivic4358
12'' Resonant Engineering XXX any good?
I have heard that with one of these, you can get 110dB, is it true? I am seriously thinking about buying one. What would the biggest, best amp be for SPL for this sub?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
HondaCivic4358 is offline   Reply With Quote
Old 11-03-2005, 08:27 PM   #2
HondaCivic4358
i've heard most people run the xxx's with planet audio amps. i was thinking either the vx2200d http://www.planetaudiousa.com/home/c...um=3&catNum=16 or the bb1250.1 http://www.planetaudiousa.com/home/c...&catNum=15#top would the 2200 be too much for the one 12? what are your opinions? anything better?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 11-04-2005, 01:58 AM   #3
GScivic7
GScivic7's Avatar
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: 12'' Resonant Engineering XXX any good?
Why would you put a shitty amp like Planet Audio to a beast like the RE XXX? Go with something that is quality. A big monoblock Kicker or MTX amp would make that sub sound killer.
Empty Pockets Racing Member #1
GScivic7 is offline   Reply With Quote
Old 11-05-2005, 12:10 PM   #4
HondaCivic4358
Re: Re: 12'' Resonant Engineering XXX any good?
What size? like the kicker 1200 d class? or what
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 11-05-2005, 03:32 PM   #5
GScivic7
GScivic7's Avatar
I would go with this puppy right here
http://www.woofersetc.com/index.cfm?...roduct_ID=2666
An RE XXX would love every bit of power from that thing.
Old 11-09-2005, 05:35 PM   #6
HondaCivic4358
wouldnt that be too much though? because i thought the way to do it was match the rms of teh sub and get that same wattage of peak from the amp.....i dont wanna blow a nice sub like that..
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 11-09-2005, 05:36 PM   #7
HondaCivic4358
wouldnt that be too much though? because i thought the way to do it was match the rms of teh sub and get that same wattage of peak from the amp.....i dont wanna blow a nice sub like that..anything equivalent....but maybe a bit.....cheaper?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 11-10-2005, 01:57 AM   #8
GScivic7
GScivic7's Avatar
They come in DVC 2ohm configuration. So you could either parallel it to 1 ohm or series it to 4 ohms. You would wire the VCs in series to make 4 ohm and be feeding it 1250 watts that's still underpowering it. For some reason I thought I remembered teh XXX only handling 1000 watts
Old 11-10-2005, 02:02 AM   #9
GScivic7
GScivic7's Avatar
Re: Re: Re: 12'' Resonant Engineering XXX any good?
you kids and cheaper...don't know anything about quality these days. This amp would do it also, you wire the VCs in parallel to 1 ohm and be feeding it 1600 watts with this amp.
http://www.ikesound.com/product-product_id/2941
Just to let you know, I have the 1200 watt version of this amp feeding two Alpine 12" Type Rs and I love it. I almost got the 1600 watt amp and 3 Type Rs, but I figured that would be overkill and didn't know if my alt would handle it. Even with a 110 amp alt, i still get dimming with my 1200 watt.
One thing I would make sure of is that your alternator can handle an amp that big. With my old civic I was frying alternators left and right because it was only a 65 amp alt and I was using an 800 watt Audiobahn amp at the time.
Old 11-19-2005, 09:11 AM   #10
Savagetendencies
Send a message via AIM to Savagetendencies Send a message via Yahoo to Savagetendencies
Re: Re: Re: Re: 12'' Resonant Engineering XXX any good?
I personally had a xxx subs with a comp series audiobahn 1200 or 1400 watt amp and it killed I was never able to turn my radio up all the way because it kept popping my trunk( I ended up getting a heavt duty latch) but even after that it started to hurt my ears.get a nice 1200-1500 watt amp on it and I am sure you can knock stuff off the wall from ur bass
Savagetendencies is offline   Reply With Quote
