Go Back   Automotive Forums .com Car Chat > Ford > Thunderbird
Old 11-05-2005, 09:36 AM   #1
munchone
92 sc thunderbird stops running then starts 20 min. later
car sometimes dies suddenly,then won't start for 20 or 30 minute.still turns over,but won't start.then later it will start.can anyone tell me what it could be.
munchone is offline   Reply With Quote
Old 11-05-2005, 11:39 PM   #2
SUERED
I have seen forum comments about the Ford THICK FILM IGNITION MODULES also known as the TFI module---causing this problem. Seems like when the failing module warms up from engine heat, it goes on break and the engine stalls without any immediate restart. If your TFI is mounted at the base of the distributor, this may be your problem. You did not report the engine size so I am guessing. The TFI module is easily identified. It is a grey plastic case with the shape/size of a conventional chocolate candy bar. Some are mounted on the condenser of V-6 engines (easily seen with the hood open --and mounted in a metal heatsink.
SUERED is offline   Reply With Quote
Old 11-06-2005, 02:19 AM   #3
flewthecoupe
flewthecoupe's Avatar
Re: 92 sc thunderbird stops running then starts 20 min. later
Considering it's a '92 SC, I'd venture to say it's a 3.8.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
flewthecoupe is offline   Reply With Quote
Old 11-06-2005, 04:34 AM   #4
~manuel~
it can be a number of things. you will have to pin point if it is fuel related or spark related. when your engine fails to start , is the upshift indicator light on while cranking?if so this indicates that the pcm is failing to recieve a signal from crank sensor, which is notorious for going bad on the super coupes.do you hear the fuel pump coming on when it fails to start? it would be a good idea to check for fuel pressure when engine fails to start. another common item that can cause this is the ignition module, its not on the distributor cuz your engine has a Distributorless Ignition System. or DIS. you will see a box located at the top part of your engine(either gray or black in color) that is labeled Motorcraft DIS. you cant miss it. however before you start throwing parts at it verify if you have spark and/or fuel during this no start condition.
~manuel~ is offline   Reply With Quote
