Old 05-23-2002, 08:18 PM
Noz Noz is offline
I'm back and a slight problem...
Hi, been away for a bit, other things to concentrate on, but I dug out my R33GTR the other day, it's so nearly finished, but there's one problem.
I cocked up the spraying of my windshield clear part, and there is a bit of erraneous black paint (quite a bit really) where it shouldn't be.
I've tried Mr Muscle oven cleaner on it, tried polishing it off with a cloth and pure friction but nothing seems to work
Is there anything else I can try?
(I'm still planning to do the 400R when the R33 is finished, btw... )
Old 05-23-2002, 09:52 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
If I read right and you were painting the black part of the windscreen and the paint leaked onto the part which needs to be clear there is two ways.
1) Use a pointed end toothpick and scratch off the paint. (It smetimes wont work depending on the amount of paint on the windscreen).
2) Use 400grit sand paper to sand the paint off, then use 800grit, then 1200grit, higher if you think you would need to. Then use a polishing compound (future floor polish...ect) and polish the windscreen. I have never tried the second option but I've seen the results and it works.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 05-24-2002, 12:15 AM
liang liang is offline
you can do without the sand papering and use just polishing compound itself if the paint isnt too thick.
" Increase speed when being overtaken "
Old 05-25-2002, 03:31 PM
Noz Noz is offline
Think I'll go give the toothpick idea a run first, thanks for the advice guys.
I'm back! And I brought the heat problem with me... FlamingTaco Caravan | Voyager 0 03-20-2004 02:07 AM
hey guys, I'm back and I have some parts to sell off a 97 GLE MaxRX7 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 12 10-27-2003 11:50 AM
I'm Back and Ready for Modeling! Honoturtle Car Modeling 17 04-17-2003 08:05 AM
I'm back... and mad... 93Civicgurl '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 10-01-2002 08:29 PM
