Go Back   Automotive Forums .com Car Chat > Pontiac > Sunfire > General Discussions
Old 10-26-2005, 03:36 PM   #1
newfysteve
1998 sunfire o2 sensor
how would i change the o2 sensor in a 98 sunfire. my car just died, bty seems fine and we can hear the starter turning over. could it be the o2 sensor preventing it from starting? if so, where do i change it and how.
i'm new to this forum, and would like any help i can get, in laymans terms if possible. lol.
thanks
steve
newfysteve is offline   Reply With Quote
Old 10-26-2005, 06:15 PM   #2
GTP Dad
Pontiac Guy
Re: 1998 sunfire o2 sensor
First of all welcome to AF!
There is slim to no chance that the O2 sensor is causing the no start condition. Generally, a no start condition is caused by either a lack of power from the battery, no fuel or no spark.
To check to see if the fuel pump went bad, get a can of starting fluid. Remove the tubing from the throttle body and spray a small amount into the throttle body. If the car starts the fuel pump is probably bad. If it doesn't start then you will have to find the problem with the ignition system.
The problem with the ignition system could be the crank position sensor, cam position sensor, ignition module or the engine computer. If you have never changed any of these you may want to get the car towed to a mechanic and have them check things out. By the way did the Check Engine Light come on before the car died?
GTP Dad is offline   Reply With Quote
