Old 10-14-2005, 07:07 PM
pimpedcelicast pimpedcelicast is offline
Send a message via AIM to pimpedcelicast
fuel pump keeps dying
Hi, we have replaced the fuel pump in a 1994 blazer 3 times now, and this time it still isnt working with the new pump, checked the relay, and even switched to the new harness like they suggest. Checked the fuse as well, can you guys think of anything else that could cause the fuel pump not to have power?
Old 10-14-2005, 07:10 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: fuel pump keeps dying
maybe it has enought power, its just that the line is plugged somewhere, and it cant get the pressure up. Have you replaced your fuel filter lately? You should always change that when you put a new pump in. Otherwise I would say that there is some corrosion in an elictrical connection somewhere, possibly try tracing your wires all the way back, and make sure all grounds are free of corrosion. But you said you replaced the harness already. I really dont know.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
Old 10-14-2005, 07:14 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
I too have a "94" Blazer that needed to replace the fuel pump. If I remember correctly there was a ground wire that needed to be attached to the upper side of the rear bumper. Was this wire re-connected? If so, Then you should be checking the voltage that is coming into the fuel pump from you ignition switch. You could have a faulty switch. No voltage no pump.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 10-14-2005, 08:27 PM
yeah the ground is reattached, going to test and see if power is coming back there, dont really want to pull the whole pump out again, but will do it if I have to.
Yes I also changed the fuel filter, fuel pressure is normal as well with the last pump i put in.
Old 10-14-2005, 09:31 PM
tblake's Avatar
In God We Trust
Originally Posted by pimpedcelicast
....Yes I also changed the fuel filter, fuel pressure is normal as well with the last pump i put in.
If you dont mind me asking, if fuel pressure is normal, then why do you suspect another faulty pump?
Old 10-14-2005, 09:40 PM
Re: Re: fuel pump keeps dying
because it quit working, so i put a new one in and it doesnt work as well.
Old 10-14-2005, 11:26 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I would replace the relay just to be sure you don't have a buggy one.
The chances of anyone having 3 defective pumps in a row is slim.
What kind of fuel pump are you using?
Old 10-14-2005, 11:38 PM
one from o'reilly autoparts, and I did get a new relay to test with.
Old 10-14-2005, 11:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: fuel pump keeps dying
Is it a carter fuel pump?
If it is, send it back and install a Delphi pump. Someone just a while ago had the same problem and when they finally installed the Delphi model, everything was perfect.
Old 10-15-2005, 06:56 AM
hmm i duno ill have to check, what is the price differences?
Old 10-15-2005, 07:45 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If it's new and it's not kicking over, meter the power at the harness to make sure you're getting full voltage, meter the ground strap..(even with that, sand down the end of the strap to make sure it's clean, and make sure where it mounts is clean)
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
Old 10-15-2005, 09:02 AM
BlazerLT's Avatar
AF -Advisor
Price difference shouldn't be much.
Old 10-15-2005, 06:53 PM
got it going, in that new wiring harness one of the wires was loose.
Old 10-15-2005, 07:46 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: fuel pump keeps dying
Ah sweet! Gotta hate it when one small connection throws everything off.
