Ring & Pinion
Maybe this is where I need to ask. What about gearing changes when you put larger tires on the X? I know if you don't change the gears you get less power transferred to the ground. Are any of you with larger tires making the change? If not what sort of fuel inefficiencies are you noticing? What about power losses? Surely you aren't complaining about LSDs if you change tire sizes without changing gearing! I posted on 4 something no replys.......... Is it just boring?
![]() Join Date: Mar 2001
I don't think anyone has taken the jump yet to switching gears? I would like to do lockers and Transfer case gears. I run stock tires during the week so that is the reason I won't switch to taller gears in the front a rear. I do have a power loss with the 31" Swampers but it's a liveable loss
We don't give a damn how loud your stereo is! Did you read your owners manual yet? V.P. of PNWX |
#3 | ||
Re: Ring & Pinion
#4 | ||
Re: Re: Ring & Pinion
Personally, I would prefer to leave my engine stock and reliable. Alot of Toyota guys run super low gears and the stock 22R 4 cylinder engine. To me, that seems like the best direction to follow in building up an Xterra. |
AC offers RP sets as well.
As for me, my 31's are fine with the stock gears. 32's would be OK if you aren't towing a trailer. I would definitely consider regearing with 33's though. Optionally, you could get 4:1 t-case gears from Calmini if you are only concerned with gearing offroad and not on. Nissan RP gears are low in comparison to those put in other manufacturers, but the transmission gears are taller. The final drive ratio/crawl ratio on Xterra's actually turn out to be about the same as other manufactures final drive/crawl ratios. |
#6 | ||
#7 | |
Thanks to all!! Now that's the kind of info and discussion I'm used to seeing here.
#8 | |
I am not all that familiar with the Frontier RP offerings. I know that the Crawl ratio with the Auto Tranny less than that of the 5speed for obvious reasons. Also, Xterra's without LSD's were equiped with taller RP than those with LSD's.
#9 | |
Considering I saw an Xterra on the trail this weekend turning skinny 36" Swampers (yes, 36) with a stock driveline on some pretty nasty conditions, I think we're in decent shape already.
I also saw a 3.0L Hardbody turning skinny 38" Swampers very effectively with the stock driveline as well. Pictures to follow in the next day or so, Brent |
#10 | |
36's? Is this a joke i.e. the TwinTurbo thread over on XOC?
#12 | |
Lower T-case gears make the world of a difference off-road, but unfortunately do little for on-road performance. The main point I was making is that the factory highway power in the normally aspirated X is weak to begin with. Its 0 - 60 time is not all that great even with the factory 265/70R-15 Long Trails (or whatever it is you may have). If you are satisfied with that and regaining that lost performance is important to you then go with the lower R&P. The gears will cost you $1,000 bucks plus installation of between $200 and $400 per gear set, depending on whether you remove the diffs or not. If you are doing primarily crawling and not pulling trailers up mountains, odds are you will have few issues other than passing. But if that is all you do primarily, say the heck with the R&P and get the T-case gears. You will get far more value for your money in my opinion. You can live with the slightly reduced power as long as you aren't running 35s or something.
#13 | |
Thanks War...
I primarily pull a trailer (boat) and no I'm not satisfied with the highway performance of the X. Especially when headed up hill in Jefferson county NC. However I would like to put 31s on my truck and not lose the performance I have now. I do drive mostly on the highway and 31s aren't a necessary just a luxury:I do hunt and fish and have some things to cross Thanks again! |
#14 | |
Nissan puts the equivalent of 31s (265/70R16 = 30.6") on the '02 SE Xterras already with the same gearing. I really don't think you'll lose any noticeable power going to 31s. You're running 265/70R15 (29.6") which were the stock size on the '00 models right? A lousy 1/2" larger radius isn't going to sap that much power. Certainly not enough to justify re-gearing.
Brent |
