Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-24-2004, 09:54 PM
Ticla Ticla is offline
Question Intake manifold please help
Crown vic 1996 100.000kilometers (60,000miles) my upper intake manifold (made in cheap plastic), just blow out, in front. just behind the alternator.
My question is it is possible to repair this with Epoxy, or other ????
I was thinking of a mix of fiberglass. Could anyone help? i call the dealer and ther asking 1000.00$ for upper intake manifold.
My last ford car
clarence
Old 09-25-2004, 09:49 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Intake manifold please help
No, it cannot be repaired.
Ford is not the only manufacturer to use a resin intake, and to run coolant thru it and have failures. They ARE the only ones to have stopped.
$1000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! They're frickin CRAZY!!!!
RUN! Call another dealer. The intake kits are about $250, and they are EASY to replace, like under 2.5 hours.
Old 09-25-2004, 02:55 PM
Samw Samw is offline
Don't even think of repairing it!
Lousy design.
Ford has a replacement manifold that uses an aluminum manifold to carry the coolant, the rest of it is still plastic. No where near $1000. Maybe they quoted you the price for parts and labor to replace the manifold(still insanely high).
Old 09-26-2004, 01:02 AM
jasong145 jasong145 is offline
i replaced one on my dads 99 grand marquis, PAIN IN THE ASS!!! i heard from somewhere on this site that Ford is recalling the cracked manifolds near where the thermostat is. if i would o knew that, i would of picked up one, instead of getting another plastic one. i thought the had plastic in 98-present. my mom has a 94 p71 and it has an alluminum one. ehh, well just look on the site about the manifold recall thing, it will save you time, and lots of aggervation.
Old 09-26-2004, 12:26 PM
ModMech's Avatar
The "recall" applies for 7years, unlimited miles. His '96 would no longer quality due to time. Also, it only applies to the cars with "P71/72" in the vin or Lincols with "limo prep".
Old 09-28-2004, 06:34 AM
Thanks to all..
clarence
Old 09-28-2004, 09:49 PM
pollenjesus pollenjesus is offline
As far as I know there has only been a recall by Ford for the intakes on police and taxi vehicals. Ford updated the intake design for 2002 model year to have an aluminum coolant passage instead of the plastic.
cheers
Old 09-30-2004, 04:09 PM
radioman2002 radioman2002 is offline
Is it a fact about the 7 years? I just changed one on my 97 CVPI. I am looking for a replacement, to keep for a spare. Also what site has the recall info?
Old 10-01-2004, 11:16 AM
ModMech's Avatar
Yes, 7years unlimited mileage.
The recall is posted a few times at www.crownvic.net in the "4.6Tech" and 4.6 Archieve" sections.
Old 10-02-2004, 09:37 AM
Warren'74 Warren'74 is offline
Send a message via MSN to Warren'74 Send a message via Yahoo to Warren'74
Did you get the intake with the aluminum crossover?? If so, you will not need a spare.
Old 10-05-2004, 08:29 AM
No I parted out a 96 CVPI, Was looking to get the bad one replaced under warrantee for a spare.
Old 10-05-2004, 08:34 AM
OIC. There has been a few decent deals on ebay for the aluminum crossover intake. Ive thought about getting one of those for my 1999, as it has been replaces, but not with the alum. crossover.
Old 10-11-2004, 10:07 AM
schwinnfever schwinnfever is offline
Banned
I tried to fix mine with JB Weld, worked for 2 mins... The problem is the alt brace is pulling on that manifold.. that is were the crack comes from.. I bought mine from Ford.. I also called ford corp to check on a call back and they ran my vin and said no.. BUT told me to hold onto my receipt in case one does happen and I could then turn that bill in and get my money.. The last thing I want to tell you is I have a friend that works at Advanced Auto Parts and he told me that they have a replacement part for that... It was too late so I never followed up on it but if you didn't buy it, give them a call or anther major parts store... The job is very easy to do... and if you don't have the tool to remove the fuel lines, you can just leave it hooked to the rail and lift the whole rail out of the way.... I suggest you buy all new injecter o-rings..... good luck
Old 08-22-2005, 05:45 AM
Nedam Nedam is offline
I've had the same trouble with my 1997 CV & couldn't fix it with epoxy. Found a used (manifold) with the alluminum coolent passage ,I replaced the old plastic one with a new pair of gaskets but i couldnt have my car to idle smoothly as it was without finding the real cause & i'm still working on that. Is it a leake or somthing else. It is realy (pain in the a...) .
Old 08-22-2005, 07:50 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The 7 year warranty is for Police, Taxi, and Limo only. You have to prove the vehicle is still in that use.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
