Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-04-2005, 10:55 PM
dalemilam58 dalemilam58 is offline
Major electrical problem
My son has a 95 talon esi...The last time we started it all the guages went wacky...and it died and wouldnt start. All the warning lights went on and off and the right side cooling fan came on. I messed with the foot feed and could hear the fan speed up as I depressed the foot pedal.
I also noticed that the throttle cable the was attached to the intake was sparking and getting hot. I unhooked the cable and started taking off harness conections to see if I could pinpoint the short. nothing worked. I finally cut a piece of gasket material and placed it under the throttel cable link that was on the intake so it would not ground to the intake. No more sparks but car will not start. It will roll over but not getting any spark. The guage lights will not light up now. I'm at a lost at what to do or where to look.
Old 10-04-2005, 11:12 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Major electrical problem
check your fuses, you might have blown one when the throttle cable started sparking
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-06-2005, 04:06 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
check out the battery, it might be fried. also check ALL the fuses, twice if you have too.
95 Talon TSI AWD
97 Eclipse GST
Old 10-06-2005, 08:58 AM
Re: Re: Major electrical problem
Thanks I finally figured out that is was a bad ground...I took a set of jumper cables and connected them to the neg side of battery then one to the engine and one to the body....everything worked... I just ran a new ground from the battery to the body to solve the problem.
Old 10-06-2005, 09:25 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Thx for posting the solution.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
