Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 10-10-2005, 08:14 AM
PrimeSi PrimeSi is offline
Send a message via ICQ to PrimeSi
What ECU for SR20DE
I have put SR20DET in my S15 but I have kept the SR20DE wiring loom and ECU.
The engine is from a S14a 200SX but I have put on the distributor from the DE engine so it would run with the current loom. I went to put on a Apexi Power FC but as this was deigned to be used with CAS and will not work with the dizzy.
What I want to know is what ECU upgrade would be best for the SR20DE to cope with the extra fuelling and airflow?
Forget the earthquakes, this is serious...we're outta beer :cry:
Old 10-10-2005, 08:41 AM
Re: What ECU for SR20DE
Just also to say im looking at the Emanage Ultimate as this has settings for the SR20DE and SR20DET.
Old 10-12-2005, 08:07 AM
no one?
Old 10-12-2005, 11:47 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
I believe you said you coulnt go to the DET Harness so I think your best bet would to be to get a Power FC designed for the DE motor... Since you have to use a Distributer then you'll have to use a N/A ECU (it sounds like the Power FC you got is from a DET?)
I would think that the Power FC from a N/A S15 would be best since thats the harness you have.
Either that or you could go to a standalone and rig up your own ignition system
Old 10-13-2005, 05:25 AM
I can not find a power FC for the DE, dont think they do one.
Old 10-13-2005, 05:45 AM
R.W.240's Avatar
Banned
Piggy-backing the OEM ECU will be the most cost effective then. its not the best solution, but it will get the job done.
but if you have the time / money theres always the full standalone
