Go Back   Automotive Forums Car Chat > Triumph > Spitfire
Old 09-30-2005, 06:12 PM
Dan Garcia Dan Garcia is offline
Replacing fuel pump on 79 spit
I am trying to replace my original fuel pump with a replacement from Victoria British however the throw doesn't seem to be hitting the cam enough to pump gas into the filter. Anyone else ever had this problem? If so, sure would appreciate hearing how you fixed it Thanks.
Old 10-01-2005, 12:03 PM
DurangoDave DurangoDave is offline
Dan - Two possibilities come to mind:
1. Is there a thick spacer between the pump and the engine block? Try removing it.
2. Maybe VB sent you the wrong pump. Re-check the part numbers.
As an aside, I strongly suggest you go to the Totally Triumph Network...this forum you are on now is virtually unused. I would be surprised if you get even one other reply here.
Dave
