Go Back   Automotive Forums Car Chat > Mercedes-Benz > General Discussion
Old 07-08-2005, 01:29 PM
g.brew g.brew is offline
300d water leeking problem
I have a leek in my 84300D. everytime it rains water pools up on the floor behind the passenger seat. I cannot find the source of the leek. This same problem is common with other w-123's. Does anyony else have this problem? If so, any solutions?
thanks!
Greg.
Old 08-01-2005, 12:38 PM
benhanson00 benhanson00 is offline
300d leak
This is a classic 123 issue with drain channels. Most likely from the sunroof, in this case. Open your sunroof, and if you look very carefully you should find a drain channel on each side that drains along the front or back corners down through the body. Unclog that and water stops building up in the channel and dripping at your feet.
Old 08-05-2005, 10:46 AM
Re: 300d water leeking problem
thanks! ill look in to it.
Old 09-17-2005, 11:11 AM
PAC730 PAC730 is offline
Hello, I was wondering if you ever found what the cause of the leak was? I have been chasing down the same thing, pool of water, rear passenger side floor, every time it rains, I'm going crazy trying to stop this. Please post if you found anything. Thanks-----Paul
PC in WPB
1997 Chevy Suburban 72,899 miles
1984 Mercedes 300D 142,956 miles
Old 09-23-2005, 09:40 AM
SUMOBOY SUMOBOY is offline
Use an air hose, not a coathanger. Put the nozzle of the hose on the drain, wrap a rag or towel around it to prevent blowback, and purge the drains. We do it here. works good.
If you don't have the toll money, can you still get to the light at the end of the tunnel?
