1995 ford tauras wont start in cold weather
my 1995 ford tauras takes a very long time to start only in cold weather
sometimes i die the battery from trying, but in the summer i don't have any problem at all. winter is coming and don't know what to do can anyone help? afraid of the cold rita |
SHO No Mo
![]() Join Date: Jun 2004
Re: 1995 ford tauras wont start in cold weather
When cranking, is the cranking speed normal, or does it seem a bit labored? If it seems a bit labored, you might just have a weak battery. If it sounds normal, then you might have to make some measurements to get a very good answer on this forum.
For instance, do you know what your fuel pressure is during the cold weather? How old are your spark plugs and plug wires? You might want to pull a couple of plugs and see how they look. You might have a coolant temperature sensor that is out of range causing the air fuel mixture to be too rich or too lean when the engine is cold. Your idle air bypass solenoid might be dirty and not allowing the proper amount of air around the throttle plate during a cold start. I'm sure there are even more items that I'm not thinking about right now. -Rod |
