Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 09-19-2005, 02:45 AM   #1
libraboy1021
oil in sparkplugs
I tried to change my sparkplugs today. I pull out the second sparkplug I noticed there is oil. Can you guy tell me what is wrong? Is my head gasket leak?
thank you
libraboy1021 is offline   Reply With Quote
Old 09-20-2005, 12:49 PM   #2
grimmis
Send a message via MSN to grimmis
If theres oil on the plug you probably have bad piston rings and you need to get that checked . the easiest thing to do is have someone pull teh codes to find out exactly wat is wrong
grimmis is offline   Reply With Quote
Old 09-21-2005, 08:30 AM   #3
knorwj
knorwj's Avatar
Send a message via AIM to knorwj
well is it oil on the tip? As in oil inside the cylinder, or is there just oil on the white part of the plug? Big difference. If its in the cylinder (on the part of the plug that actually fires) then it could be a number of serious problems. However if it is just down that tube where the spark plug wire and spark plug connect and on the white part of the plug then it is a cheap fix. In this case its just four little ring washers you get from the dealer for $2.00 each and then pull off the valve cover to replace them.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
knorwj is offline   Reply With Quote
