Paint Codes
I want to know if there any websites out there to find out what color is painted on your rig?
AF -Advisor
![]() Join Date: Sep 2003
Re: Paint Codes
Check your door bro.
Should have the paint code. |
I've looked for the paint code on the door jamb but to no avail. Shouldn't it be a WA#. How do I get the code if not one there. Mine is a 98 2dr 4wd and is a forest green color. Anyone have any suggestions??
#4 | ||
![]() Join Date: Dec 2004
Re: Paint Codes
That may not be exactly what you're looking for, as a "color code", but that does tell you the GM color name. If you don't have "43U" on the bottom of the list, post the number codes and I'll give you the color definition. |
#5 | ||
Problem?
Re: Re: Paint Codes
The code that I found is 92H. The code was in lower right corner of sticker; Is this right?
#7 | |
Re: Paint Codes
92H refers to the cloth seat color, which is Medium Dark Pewter.
You do not have a 43U? Do you have a 87U? I have 92H listed in the lower RH corner as well, as well as on the last line which is apart of the main codes. Look, and post, your numbered codes that you find near the bottom list of the main section of codes. |
#8 | |
I am also trying to find the color for my 98. Having an issue myself!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
#9 | |
Re: Paint Codes
Post your numbered codes near the bottom half of the main section of codes, from the SPI sticker located inside your glove box. Most color codes for the '98 Blazer appear to start with a number. If you post it, I can give you the GM color name.
#10 | |
Problem?
Re: Paint Codes
Yes the paint code will be a number followed by a letter.
The number indicates the color The letter indicates what the color applies to..... "U" (upper) is the primary color. "L" (lower) is the secondary color (two tone) "A" (accent) would be the color of the stripe....etc |
#11 | |
Thanks I will post when I have time to get out to my truck. Thanks again! I believe it is Cherry, or Dark Cherry. Pep Boys tried to sell me torch red, that didn't work!!!
#12 | |
Problem?
Re: Paint Codes
Dark cherry should be 94 I believe, so look for 94U on the list.
#13 | |
Re: Paint Codes
Who was the guy that posted the pics of his Blazer that was red with the silver on the bottom? The two tone paint one? It looks real sharp and clean? That is my exact Blazer! Let me know if you know what I am talking about. Thanks
#14 | |
Ok here we go, this is my exact Blazer, it is just TonyMazz's
here is the link, anyone know the exact name of this color? http://www.automotiveforums.com/vbul...d.php?t=418208 Thanks guys!
#15 | |
Ok, I do have a 43U in the last row of codes. I would guess that should be the one, do you know the color name for that code and does this translate in anyway to a WA # for the gm paint codes?
