Re: keyless entry
You can do up to 2 remotes for the 94, it will not accept any more than that.
To program remove the bezel housing the Trac Off switch by pulling straight out on the left side of the bezel then grasping the right side and pulling (the bezel is clipped on each end to the dash) Remove the harness connection from the traction control switch. there are only 4 terminal connections in the harness connector, orient the connecter so that 3 of the connections are arranged vertically top to bottom on the left side and the 4th is at the bottom right of the connector forming an "L", take a small paper clip and bend it so you can insert it into the 2 bottom left and right connections, turn the vechcles ignition switch to the ON position, the door locks should cycle, press the lock or unlock button of the remote and the locks cycle again, if you have a 2nd remote for the car press it's lock or unlock button and the door locks will cycle again, then turn off the ignition key and remove the paper clip.
Test the operation of the remote(s) to verify they are working with the vehicle. Plug the Harness connector back into the Trac Off switch and clip the bezel back to the dash and your done.
This will work on the 93-95 LH bodied models, If the vehicle does not have a Trac Off switch the harness connector will still be there attatched to the bezel but will only work if the vehicle is equipped with keyless entry from the factory. There is a way for the OBD-2 cars to be programmed but I am unclear on that, it is better to do it properly with the correct scan tool at a dealer.
