Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-11-2005, 10:59 AM   #1
Rusty280Z
Send a message via Yahoo to Rusty280Z
Need info on removing alternator, 92 Cutlass 3.4
Does anyone have any alternator removal tips. Trying not to disconnect the half shaft according to the Chilton's manual.
Also, what would be a price quess on having a garage do it?
1992 Cutlass SL, 3.4 Liter, automatic.
Any suggestions would be appreciated.
Rusty280Z is offline   Reply With Quote
Old 09-12-2005, 08:56 AM   #2
Manny_boy
Manny_boy's Avatar
Re: Need info on removing alternator, 92 Cutlass 3.4
The only choices you have are 1-remove the passenger side tie rod (some people claim to have to get an alignment after this one); 2-drop the rear of the subframe; and 3-remove the axle (which is actually the easiest way - once you remove the hub, the axle just pulls out) - most of the quotes from shops are in the $450.00 price range.
Behind a calm face is a disturbed mind controlled by music...
Junkyard Dog - Be careful...it bites!
Manny_boy is offline   Reply With Quote
Old 09-12-2005, 04:47 PM   #3
theragtopguy
I suggest that you go to www.w-body.com
Look under the FAQ section, theres a procedure to do it by.
or go to www.60DegreeV6.com
You can go to the maintenance section there, method with pics is available to look at.
Good luck. To me, best way is to drop the axle. Did it two times myself that way.
theragtopguy is offline   Reply With Quote
