Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 09-05-2005, 09:02 PM   #1
abs10
1995 Blazer s-10 auto transmission trouble
I have a 1995 s-10 Blazer - 4.3V6 4WD automatic and suddenly, it will not engage in any gear in 2wd. The fluid level is OK. It will shift into 4WD and drive, but not 2wd. When I put it into park, it makes a clattering/grinding noise.
Any suggestions where to start looking?
Thanks.
abs10 is offline   Reply With Quote
Old 09-06-2005, 11:56 PM   #2
OverBoardProject
Banned
Re: 1995 Blazer s-10 auto transmission trouble
Not too many tranny prople on this board, so we might not be able to help you.
But do I understand you correctly that it'll work properly in 4wd?
When driving? (don't try it on dry pavement)
If this is the case it'll probably be your transfer case.
Which wouldn't be too bad since the job is easier and the parts will probably cost less
OverBoardProject is offline   Reply With Quote
Old 09-07-2005, 12:11 AM   #3
Vortec350S10
so are you saying when your in 2wd its like your in nuetral? Maybe somebody stole your rear driveshaft! lol.
When you put it in park is it more like a ratcheting noise? I bet your tranny's output shaft is spinning and there is something obviously disconnecting it from your rear end somewhere along- probably in the T-case like overboard said. It ratchets because its like putting your tranny in park when your still moving. The parking pawl in the tranny ratchets.
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Vortec350S10 is offline   Reply With Quote
Old 09-10-2005, 12:17 AM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
Thanks.
It would help if you actually responded.
BlazerLT is offline   Reply With Quote
Old 09-10-2005, 11:29 AM   #5
abs10
Re: Re: 1995 Blazer s-10 auto transmission trouble
Hi,
Sorry for not responding sooner. It turns out that it isn't the tranny or transfer case after all - the pinion gear is sheared. Would anyone know what rear ends would swap in with a minimum of aggravation? I figure it may be cheaper to go this route than to have a shop set up a new rear end assembly for me.
Thanks again.
Old 09-10-2005, 10:37 PM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
You shoudl be able to swap in another rear end from 95 or 96 if my memory serves me correctly.
