Go Back   Automotive Forums .com Car Chat > Mazda > RX-7
Old 07-28-2005, 06:33 PM   #1
jong0124
87 RX7 N/A- Need help to increase HP.
Hey anyone out there with the know how to tell me some of the cheaper mods (Besides exuast and high flow intake) Because that is a givin. I would like to bring my hp up with out having to change rear end and tranny. Any help would be appreciated.
jong0124 is offline   Reply With Quote
Old 07-28-2005, 10:24 PM   #2
NuTbAgSaN
NuTbAgSaN's Avatar
Send a message via Yahoo to NuTbAgSaN
eh, what mods are there that are cheaper and add power besides intake and exhaust...haha im lost. intake and exhaust are the 2 big ones in this category, really anything else is going to be more expensive
NuTbAgSaN is offline   Reply With Quote
Old 07-28-2005, 10:43 PM   #3
lamehonda
lamehonda's Avatar
Re: 87 RX7 N/A- Need help to increase HP.
Yeah, other than a coffee can and neons, there is no cheaper way to get more hp.
lamehonda is offline   Reply With Quote
Old 07-29-2005, 12:49 AM   #4
FDTT
Well there is not a hole lot you can do for little money to get a NA RX7 to go fast.
some things that i woudl suggest you to do are weight reduction types of things.
airpump and bracket=8lbs
IAC valve with silinoids=1.5lbs
A/C=58lbs (including all lines and such)
ect ect
You may also want to look at pickin up a set of aftermarket rims. Dont have to be the best thing out there but if there lighter than the ones you have on there then you will put that power to the ground much better.
As for performance upgrades, like you said you know of intake and exhaust.
But you want a full cold air intake with cold air box isolated from the engine bay. This is going to gain you some noticable power.
Next you want to work on a full block bacl exhaust. 2.5" piping is the best as you want to retain some backpressure in the system for thisng to work the best.
Next i usualy go with ignition. There is no emediat gain to be had with ignition but with this you insure that the fual and air mixture is getting burn fully. If your existing ignition is aged then this is a good thing to do.
After that i go to the drivetrain of the car. Start off with a good clutch. ACT, Ceneterforce, Bonze, Clutchmaster all make a good clutch for the car. The have a look at the flywheel. The less rotating mass, the faster you get the revs up and the sooner you are making usable power. I know you said you dont want to change the rear end. But often this is a cheap way to get more perfoamance out of the car. Find a used LSD and rebuild it. (if you dont alreayd have one)
This is all i can really think of right now. Othere than taring down the motor and doig some port work and such. But you do all the above and you will notice a good gain in performance of the car.
Dont drive faster than your angels can fly
FDTT is offline   Reply With Quote
Old 07-29-2005, 03:03 PM   #5
NuTbAgSaN
NuTbAgSaN's Avatar
screw intake...with an n/a i just say carb the sheet. but that doesnt fall into the cheap category...probly around 1000ish to get everything?
Old 07-29-2005, 05:08 PM   #6
FDTT
$1000 is cheap for a big power gain IMO. I have guys who spend over 10k to gain a few extra horses or drop a few tenths in the 1/4 mile.
Old 07-29-2005, 09:14 PM   #7
NuTbAgSaN
NuTbAgSaN's Avatar
^ i agree...a carb can add a ton of power thats why i wish i could get one! damn on this car to get the most power out of the car as far as i know, u have to get a carb on there =\ when u think about all it includes its very good bang for the buck
Old 07-30-2005, 12:34 AM   #8
jong0124
What exactly do you mean by the carb. Do you think I should drop the fuel injection and go with carb??? I'm kind of knew to the tunning thing so if i sound stupid-- you know why.
Old 07-30-2005, 02:23 AM   #9
FDTT
You can actualy make more power running FI than carbs, but the amount of money you would have to spend on a stand alone fuel system woudl negate the extra power for most people.
And the reason they use carbs for racing alot of the time is because there is less to go wrong. The mechanics of a down draft card are simple compared to the circuts of a FI setup.
Old 07-30-2005, 04:58 PM   #10
NuTbAgSaN
NuTbAgSaN's Avatar
thats what i love about carbs, it makes everything way more simple.
and i have never heard of anyone trying to use a crazy stand alone fuel system on an n/a s4...no matter what you do i dont think either way you could make 300. not the average person at least, for my s5 n/a i figured 250 at best for what i originally was going to do. so a carb just makes more sense i think.
damn 3rd gens i wish i had the money (and a new daily driver) so i could do more fun stuff to the fc
Old 07-30-2005, 06:22 PM   #11
FDTT
Do you have a 3rd gen (FD) or a 2nd gen (FC)?
Old 07-31-2005, 12:31 AM   #12
NuTbAgSaN
NuTbAgSaN's Avatar
i have both
Old 07-31-2005, 04:34 AM   #13
FDTT
Good stuff. Ive had my share of FD's, but i always end up playing with the FC more. So no FD for now.
Old 08-01-2005, 11:55 PM   #14
jong0124
Hey man do you know where i can get the kit to convert to a carb setup.
Old 08-02-2005, 01:12 AM   #15
Soyo
Soyo's Avatar
Send a message via AIM to Soyo
just buy a turbo
no but seriously, I think racing beat has a carb setup
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Soyo is offline   Reply With Quote
