Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 03-09-2006, 05:53 PM
Ramming96 Ramming96 is offline
Must open with keyless
Mom has 95 Concorde if you unlock doors with keys it well start and stall. Open with keyless all is OK.Drive away
Old 03-12-2006, 09:03 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Must open with keyless
Sounds like you have a factory immobilizer. The remote would deactivate the immobilizer when used.
Most cars with an immobilizer would have a chip in the key, which would be recognized by the system allowing the vehicle to run like normal.
Is this the FACTORY keyless entry you are referring to.....or an aftermarket keyless/alarm?
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-13-2006, 05:53 PM
Yes it is factory keyless. Is there some way to fix it? I do'nt want it to start doing it with keyless. And have Mom out some place.
Old 03-15-2006, 07:09 PM
Onblsht's Avatar
Authorized Vendor
It sounds like you might have 2 sets of keys, but only 1 remote. I'd suggest just adding a remote to the system. The remotes for the 95 Concorde you can program yourself without dealer help.
Old 03-16-2006, 12:37 AM
sneakybert sneakybert is offline
There is a switch on the door lock clylinder on these vehicles . When the switch fails ( usually because of a pressure washer or a drive through car wash) the alarm system will not disable when you turn the key .
