Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-27-2005, 12:50 AM
reavis240 reavis240 is offline
Question power surge?
OK here is my problem. My car was driving awsome and all at once the idle is horrible and it is acting like it is missing. I put new plugs in it and it is still doing this so I bought some new wires I am putting them on tomorrow but I wondered if anyone else had this problem. It is idling so bad that the whole car is shaking. Could it be a bad motor mount also causing the shaking? Yes it is on a 240sx. I thought maybe a bad O2 sensor as well maybe making it run rich? HELP PLEASE!
Reavis240
Old 08-27-2005, 01:07 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: power surge?
could be alot of things
check timing chain, plugs/wires, and do a compression check
it really sounds like one (or more) cylinder(s) is not firing well or at all
that would cause a bad shaking motor
check distributor cap for damage too but probly not the problem
probly not 02 sensor or motor mount
if your timing chain is the culprit you may have damage to your valvetrain as well
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-27-2005, 01:11 AM
x~Underoath~x's Avatar
x~Underoath~x x~Underoath~x is offline
Send a message via AIM to x~Underoath~x
Re: power surge?
Or, it could be your TPS, errr something like that. It doesnt let enough air in to let it idle properly, so it acts like it wants to die all the time, and that shakes it up pretty rough...so up the idle a little bit and its at least a temp fix. How long that will last, you say? Ill tell you when mine dies.
Also, check your injectors, seals, and wiring harness....
1990 Nissan 240sx SE(5spd)(Megan R. Coilovers)(5Zigen FN01rc 17x8 +35: For Sale)
Wanted: Some sort of 15-16x7-8" mesh wheels, black w/polished lip. And a nice offset.
DRFT 1337 [8:10 P.M.]: i figured out how to make my dick 12 inches
OurOnePassion [8:10 P.M.]: WOW
DRFT 1337 [8:10 P.M.]: fold it in half
DRFT 1337 [8:10 P.M.]: that is how i make it 12
Old 08-29-2005, 08:29 PM
wotandsdwys wotandsdwys is offline
Re: power surge?
first thing I thought of was O2
I hooked up a stereo and forgot the ground wire for my wide/O2, and it ran like you're talking about.
