01 r/t codes
Need help on two codes,
the car is a 2001 neon r/t. The codes are p1390 and p0420 Thanks Scott
Dont worry it will work , Now hand me the Duct tape |
Re: 01 r/t codes
P0420 = CATALYST 1/1 EFFICIENCY FAILURE |
Re: 01 r/t codes
OK how much of a PIA is it to get the timing belt back into spec??? becaue right now I have no problem with it, LOTS of HP, and the idle is smooth I think right now more then before.... And On the 2nd code, I was waiting on that one, since I dont have a cat conv anymore on the car!!!!
Re: Re: 01 r/t codes
Re: 01 r/t codes
I will swing by AZ after work and get the code read by them, since I need a PS belt... Lost mine on the way to work, I think it walked off the Idler...
Re: 01 r/t codes
If it did skip a tooth, I would have to rip apart everything, wouldnt I , like take the head off again
Re: 01 r/t codes
ok I pull the P1390 code it was the same as I looked up last night with the timing skiped 1tooth or more, but the defination I had was "Relationship between Cam and Crank signals not correct"
Re: 01 r/t codes
I will stop at AZ have the clear the code and see if that makes a diffrents... and by the way, if you dont mind I added you to my yahoo and AIM list
Re: 01 r/t codes
Oh, and no I dont have any after market stuff on my car, it is all stock
Re: 01 r/t codes
I wasnt there at the time my brother put the head on..... so I have no flippen clue, he claims it was DTC, like I said it is running strong, maybe the timing is retarded a little, that why it is throwing the code. I will do a compression check tonight and see if everything there checks out. if the compression is find, should I not worry about that code then?
Re: 01 r/t codes
Knowing by brother, and the way he wants to hurry at times, I am sure it is off a little, It is running strong, I will check the compression tonight, I am not worried about the CEL because until I put a new cat on I will have that light on, I am in the process of finding someone with a welder That I can borrow
