I am the original owner of a 1995 Wrangler Sahara I6 3 spd. auto.
It currently has 74K miles. The maintenance has been performed regularly. Yesterday it suffered a catastrophic lower end failure. It will be Monday before the shop starts the teardown. At the time of failure: 1: 70 to 75 mph on freeway 2: oil pressure 55 to 60 psi. 3: temp 200 to 210 F 4: No unusual noise to indicate impending failure Has anyone experienced a similar occurence? Thanks! |
I have heard that some of the I-6 from 1995 and earlier could suffer a crank walk problem. Seems less likely since you have an automatic transmission.
Caution: Monkeys bite!
Re: 1995 I6 Failure
Aiiee that's bad news indeed. Lower end failure, blah. Any news from the shop? It's been a couple weeks.
Ours: 2020 Jeep Wrangler 2.0, 53k 2013 Toyota FJ Cruiser, 84k Kids: 2005 Honda CRV, 228k |
![]() Join Date: Apr 2005
Re: 1995 I6 Failure
I am interested in this, as its the same engine as mine. But I got manual transmission.
What is crank walk? |
The teardown as yet has not started. I requested that the shop not start until the 25th. I'm still attempting to deal with DaimlerChrysler. I maintain that a properly maintained engine (which this is) should not fail at 74K. I am curious as to what will be found inside of the engine. Something has tied a knot in the end of the dipstick. It cannot be removed.
Well it sounds like the bottom end flew apart. It's will be really hard to determine if it had crank walk if the entire bottom end came apart. When my engine died my connecting rod broke and put a nice hole in the side of the block. So I bought a working engine with 110k miles and it had a terrible blow-by problem. So I built a stroker out of it. If Chrysler won't cover the loss and you want to keep the jeep, it's a great chance to build a stroker engine, especially if the engine is still useable. Good luck man!!
J.E.E.P. = Just Enjoy Every Problem or Just Empty Every Pocket
1995 Jeep Wrangler 3 1/2" lift 33x12.50 tires 4.5L stroked I-6 Bored throttle body & Cold Air Intake Jet Chip Stage 2 Jet Thermostat Colorado Off Road Rig!!! |
#7 | |
Re: 1995 I6 Failure
Good luck with Chrysler; I agree that a well maintained engine should last, especially the 4.0. Hopefully you've got the maintenance records.
Let us know what happens....
#8 | |
I do plan on keeping the Jeep. I doubt the engine is usable judging from the coolant mixed with the motor oil that was draining onto the shoulder of the road. Probably won't go radical with a rebuild because it's my daily driver in bad weather.
I have literally every receipt for every part, accessory, maintenance item and labor since I took delivery of the vehicle. I've made copies of all and made a small bound booklet which I presented to the shop. That's one reason I'm so ticked with DC. The Zone Rep wouldn't even come to the dealership and inspect the machine. I was hoping the rep would look at the overall condition of the Jeep, the damage to the engine and the maintenance records. Nope, 10 years old, nothing they can do. I've asked everyone that I've spoken with at DC if they are telling me that 74K is all I should expect from one of their engines and they won't give me an answer. I sent two letters to Corporate last week. I'm anxious to see IF they respond and HOW they respond. |
#9 | |
Re: 1995 I6 Failure
Awesome receipts. Hope someone responds, but at 10 years old I wouldn't hold your breath....
(But I'd still like to hear what they have to say)
#10 | ||
Re: 1995 I6 Failure
#11 | |
#12 | |
Just tonight picked up my Jeep. $5100. No help from Daimler Chrysler. They're hung up on the age of the vehicle. #5 rod broke in the middle, a six inch diameter hole was made and the camshaft was broke in half. (And just for kicks, a small hole was made in the oil pan) If I can figure how to reduce my photos to the required size, I'll post a couple. That engine was a WRECK!
The dealer didn't quite follow the rules of this state when it came to proper notification of an increase in the repair estimate. I'm working on that. And I haven't given up on dealing with DC. Between e-mails and letters at least I'll improve on my typing. |
#13 | |
Re: 1995 I6 Failure
Broken rod on the highway....not good....
Let me guess....they gave you an estimate for the complete repair, then went and did a whole lot of work and put extra charges on the bill that were not run by you before you arrived. No call from Joe the repair guy saying, "well, you have a ()*&^ that's broken, it's $$$ to fix is that ok to do". You should only be on the hook for what they quoted you, since you didn't give the approval for the additional work. (I'm taking it that they were putting in a new engine, or rebuilding the old one). Time to call the BBB.
#14 | |
Re: 1995 I6 Failure
Man, you must have had the dealership bugged! Here's the timeline:
Monday 26 April, work started, shop manager calls me at work about midday and requests $2000 to order the short block, gave him a credit card #. No mention was made of an increase in the estimate. Shop manager told me it would probably be two or three days for the short block to arrive. Tuesday 26 April, on arriving home from work, found a message on my machine from the shop asking me to call or drop by. On arriving at the shop, found the short block bolted into my Jeep. At that time the shop manager tells me the new estimate is $5100, an increase of 24.4%. Well, since the job was half complete, I okayed the quote. At this point I'm grinding my teeth and jamming my hands into my pockets to prevent myself from saying/doing something "inappropriate." In addition to the engine work, I had requested a brake inspection be performed and to give me a quote before starting any brake work. Wednesday 27 April, after work I receive a call from the shop manager. He tells me I need EVERYTHING and it will cost $800! I tell him the HELL with the brakes and to button it up. I hung up the phone and sat down at the computer. Filed a complaint with the Ohio AG. I have a case number and am pursuing. After that, I looked in the nearest mirror to see if a flashing arrow with the word "sucker" was hanging over my head. (HA, HA) Some times you get the bear, sometimes the bear gets you! |
#15 | |
Re: 1995 I6 Failure
Man, I've got to quit posting late at night. I just looked at my last post and caught a mistake. It should read Monday 25 (not 26) April.
Also, I did get a response from corporate. A woman identifying herself a the "senior representative" for Dr. Zetsche phoned me to tell me that there was nothing they could do because the Jeep was 10 years old. She wouldn't tell me that a failure at 74,000 was normal and no one has responded in writing. Guess they don't want to go on record telling a customer to take a hike! |
