Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-20-2005, 11:23 PM
kirubel98 kirubel98 is offline
1999 Toyota Camry intermittent stall
I have owned my 1999 Toyota Camry for three years and now has 96000 miles on it. I recently changed the timing belt and since then, the car intermittently stall. It anly happens when I step on the break for a complete stop after driving it for 30 miles or so. It runs fine again after it cool down for a few minutes. I took the car back to the mechanic and have them check the timing belt and they replied that nothing wrong with what they did. The car has to be in stall condition to be able to figure out what is wrong with it.
Did anybody has similar problem and can tell me how you fixed the problem? Do you think it has to do with the new timing belt or something else?
Thanks
Old 08-21-2005, 01:21 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1999 Toyota Camry intermittent stall
Check the crankshaft position sensor and the sensor part of the crank timing pulley. The pulley may be damaged - scratched.
Check your distributor cap, rotor, air gap, etc. Sounds like ignition problem.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-21-2005, 08:07 AM
Erndog1369 Erndog1369 is offline
I suspect a sticking EGR valve.. take a look there.
Old 08-21-2005, 12:02 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Isc/iac
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
