Old 08-04-2007, 07:37 PM
ezd20 ezd20 is offline
Angry Over Heating...
Hi, my 2000 jeep grand cherokee.. Fan won't cut on...I checkd the FUSES under the dash,and under hood and they both seem to be FINE...My friend disconnected the FAN and hooked it straight to the BATTERy...and it worked...Since it won't cut on my vehicle want to over HEAT...any suggestions would be GREATLY appreciated..thanks
Old 08-04-2007, 10:23 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Over Heating...
could be the sensor, could be an air pocket, could be a plugged radiator, stuck t-stat
Lots of things
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 08-06-2007, 03:21 PM
btilley2006 btilley2006 is offline
Re: Over Heating...
Grand Cherokee are common for having a Cooling fan module go bad in them. It looks like a relay and is mounted below the right headlight behind the bumper fascia. Hope this helps!!
