Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 07-27-2005, 04:30 PM
D16Z6_turbo D16Z6_turbo is offline
AT transmission problem!
I'm having transmission issues with my 92 Civic w/automatic tranny. If i drive it regularly then it's fine, but when you try to accelerate or floor the gas then the rpm just climbs. The manual said to check for low fluid but I've already done that and the fluid is within specs. Anyone ever delt with this kind of thing on an automatic transmission before? Any help would be appreciated. Thanks!
Old 07-27-2005, 08:35 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: AT transmission problem!
is the fluid burnt?? when was the last time you changed it?
Old 07-27-2005, 11:02 PM
QUICK_EG_B16A QUICK_EG_B16A is offline
Well, assuming you have what your screen name implies, it's been my experience that the SOHC trannys aren't made to handle any extra major power, unless you have the gears upgraded. After putting a JRSC on my d15b (forget the last number but it was the non-vec) 6 months later the tranny was grinding like crazy, and eventually froze up all together. It was a manual though.
Old 07-28-2005, 12:19 AM
NO, im not turboing this civic...It's just my daily driver so it's 100% all stock! The color of the fluid was still pinkish/red like new fluid.
Old 07-28-2005, 10:20 AM
Kind of a Big Deal
Old 07-28-2005, 11:22 AM
Fluid was changed 3 days ago.
Old 07-28-2005, 01:13 PM
Kind of a Big Deal
what kind of fluid did u use?
Old 07-28-2005, 03:47 PM
Dexron III
Old 07-28-2005, 06:49 PM
Kind of a Big Deal
hmm... sounds like everything was done correctly.. how many miles on the tranny, it could just be that its time for a new tranny,...
Old 07-28-2005, 07:40 PM
Re: Re: AT transmission problem!
I don't like the sound of the new tranny part...This car is just my daily driver so i don't want to spend too much cash into it..I just drove the car today and focused on the slipping tranny more and found out that it only slips during a hard acceleration and gear change. For example, i'll go from a stop sign with 3/4 throttle and when the tranny starts to change into 2nd gear, then 2nd gear won't engage unless i ease off the gas pedal. So if i keep my gas pedal at 3/4 throttle or more then the motor will just rev and the car won't go. Does this explain it alittle bit more?
Old 07-28-2005, 08:57 PM
Kind of a Big Deal
ya, it sounds like the tranny is giving up, limp it like youre doing and start saving for a new one (or one from a used one) you could PM "E Honda" he just did a auto to manual conversion, he may still have the tranny and sell it to you.
Old 07-28-2005, 09:23 PM
Okay. Thanks for all the help. I really appreciate your help!
Old 07-29-2005, 12:05 AM
Kind of a Big Deal
anytime, glad i could be of service.
Old 07-29-2005, 04:11 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Used Honda auto trannies aren't that expensive. I bought mine for my old civic for $150 and spent about 3 hours to swap it out with the help of a friend. Tranny shops were estimating around the $600 range for a complete tranny swap, parts and labor.
Empty Pockets Racing Member #1
