Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 05-10-2005, 12:03 PM   #1
stangfreak7
Send a message via AIM to stangfreak7
clutch squeaking...
I have a 94 mustang gt and the clutch when completely let out makes a chirping or squeaking sound much like a little bird or something. It did this before and after a new throughout bearing and pressure plates were installed. I was wondering if anyone could help me put an end to this annoying problem. The noise doesnt affect preformance but its annoying having to lightly touch the clutch pedal to get it to go away all the time. Any help is greatly appreciated....thanks
stangfreak7 is offline   Reply With Quote
Old 05-10-2005, 02:57 PM   #2
TheStang00
TheStang00's Avatar
Re: clutch squeaking...
no freakin crap, i think im having the same problem on my 2000, does it do it real bad when you brake sometimes to? not every time though
TheStang00 is offline   Reply With Quote
Old 05-11-2005, 11:00 AM   #3
stangfreak7
yeah sometimes it does...
Old 05-12-2005, 10:01 PM   #4
fordtrucksonly
fordtrucksonly's Avatar
Normal, just does it, did it on my 87 stang, and on my truck i have now.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
fordtrucksonly is offline   Reply With Quote
Old 05-13-2005, 03:51 AM   #5
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
Sounds like the throw out bearing. Did you just recently do a clutch swap, or adjust your cable? If there's too much preload on the TB, it will constantly be in motion, causing it to wear out quicker. From what I remember, there's only supposed to be 10 ft-lbs of preload on the cable/bearing.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
Old 05-16-2005, 09:34 PM   #6
stangfreak7
thanks for the ideas, i need to check into that, how can i check the pre load on the clutch cable. The bearing only has about ten thousand miles on it, but i has done this with the old one too and ever since it hit about 55,000 miles...
Old 05-31-2005, 11:08 AM   #7
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Not sure if you fixed this yet, been a while since I've been around. 10 pounds is not much force, you basicly want to take the slack out of the cable and tighten just a bit more. The use of a firewall adjuster comes in handy here with fine tuning.
-2013 Ford Flex
-1999 Ford F150
Old 05-31-2005, 11:59 AM   #8
TheStang00
TheStang00's Avatar
my clutch has over 70k on it now anyway, im just gonna replace mine, probably get a hi-performance one too. but im not sure which one to get right now.
Old 06-23-2005, 08:59 PM   #9
mustangibew
Send a message via AIM to mustangibew Send a message via Yahoo to mustangibew
squeeky clutch
I had that same problem and tried new throw out bearings etc. It came down to having to but a "steel" throwout bearing retainer. The factory one's are made of aluminum. Since doing this I have had no noises for the last 50,000 miles. Plus it shifts ( 5 spd) smoother also.
mustangibew is offline   Reply With Quote
Old 06-23-2005, 09:38 PM   #10
BlackGT2000
BlackGT2000's Avatar
I just had a new clutch and throwout bearing put in last summer and the thing has been squeeking ever since. Apparently its normal and dosn't effect anything. I will agree wholeheartedly that its annoying. I would do the steel bearing thing but I dont think its worth it for me to pull the trans off just to get rid of harmless squeeking at this point.
BlackGT2000 is offline   Reply With Quote
Old 06-23-2005, 10:56 PM   #11
mustangibew
What will eventually happen by not taking care of this?
The T.O. Bearing will wear down the retainer and possibly put grooves in it and cause "sticky" shifting. Why Ford made these outta Aluminum is stupid. The retainer costs around 50$ and is really quite easy to put on.
1993 Mustang LX Hatchback 5.0, Black paint, black interior with white pony wheels. List of mods to lengthy to list all.
Old 11-08-2005, 03:55 AM   #12
mingtoy
you should replace your clutch because when your throwout bearing goes out it starts chipping away at the gear in your clutch after a while
at that point or throw out bearing is going to continue to fail and squeak
mingtoy is offline   Reply With Quote
