Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 08-10-2005, 09:33 PM
xxtomorrowsliexx xxtomorrowsliexx is offline
door panel
i have a 2002 grand am gt coupe. i have an extremely bad rattle on the right door panel near the speaker. i am writing to ask anyone who knows how to remove the door panel to please let me know so i can take off the panel and try and fix the annoying as hell rattle. anyone who knows please respond...or anyone with a similar problem you are welcome to respond as well....thanks a bunch
Old 08-10-2005, 10:20 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: door panel
first, you need to remove the bezel screw behind the door handle. Remove that, and pop / slide out the tray. Next, pry up the controls, and disconnect them. Unscrew the screw exposed down in the cavity. Next, pry up the reflector on the edge of the door, and remove the philips head deep behind it. Remove the screw at the base of the door grip-handle as well. Remove the triangle-shaped tweeter housing at the top by squeezing it and pulling. Now you can work your way around the door, pulling outward and pulling out the christmas tree fasteners. (it will sound like your breaking things, but you're not). Good luck.
Old 08-11-2005, 11:06 AM
got it no problem... speaker had fallen out of door mount..good directions...thanks alot bud
Old 08-11-2005, 02:19 PM
Ridenour's Avatar
GranddAmnit
Re: door panel
no problem - glad you resolved the problem.
Old 08-11-2005, 05:21 PM
pysco pysco is offline
Re: door panel
whould it be the same for the rear door except for the tweeter.
Old 08-11-2005, 06:30 PM
Ridenour's Avatar
GranddAmnit
Re: door panel
It should be; yes.
