Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 07-16-2005, 03:26 PM   #1
binga
Air conditioning problem
I have a '99 Silverado with 168,000 on her. The a/c belt broke about
15,000 miles ago.... had a new one put on... it broke after 8,000 miles...
had a new tensioner and belt put on... so far so good as far as breakage.
The problem now is that it seems to work, blowing cold a/c in the morning usually, but it cuts out sometimes and just blows warm air.
I've noticed on the freeway sometimes, if I stomp on the peddle,
it will start blowing cold air again. This also happens while stopped.... if I accelerate fairly quickly, it starts blowing cold air. Does this sound like some sort of switch problem, clutch or what? Thanks for your help!
Bob
binga is offline   Reply With Quote
Old 07-17-2005, 04:48 PM   #2
chuck16
chuck16's Avatar
Re: Air conditioning problem
Sounds like maybe the clutch on the compressor is too tight or something? Perhaps your Compressor is going and is near seizing????
Or you may be getting low on freon...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
chuck16 is offline   Reply With Quote
Old 07-18-2005, 02:10 PM   #3
twomorestrokes
twomorestrokes's Avatar
That's odd. The A/C should blow WARM air after full throttle accelleration, as the clutch normally disengages to reduce drag and comes back on when normal driving is resumed.
Maybe Chuck's right and you should have your freon checked. When freon is a little low it will cool well until outside temp and humidity go up.
twomorestrokes is offline   Reply With Quote
Old 07-18-2005, 11:48 PM   #4
sportin83
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
if it is breaking belts then i would guess the compressor is locking up or the belt is way to tight but i would say get a new compressor
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
sportin83 is offline   Reply With Quote
Old 07-19-2005, 05:09 PM   #5
rdptrans
A/C cycleing switch, this is attached to the accum.
rdptrans is offline   Reply With Quote
