| Audio/Security car audio, security. |
I don't know if it's been done before, but I have come to an ingenious solution to disassembling our entire rear seat to change the speakers!!!
I am going to go in and dremmel out a hole just large enough to have direct access to the rear deck speakers and I'm also working on a way so that the rear grilles will simply snap-off or lift-off the rear deck!!! When it finally gets warm enough, I'll go to it, and trust me when I say that there will be pictures all the way through the process to keep you all up-to-date on how the modifying is coming along!!! PS--If you have any advice for me on this project, feel free to post it up in this thread! Thanks!
Like a boy - but BETTER! 2005 Subaru Forester 2.5X 1997 Honda Civic EX Coupe Inform yourself: AF User Guidelines |
i thought about the rear speakers when i was replacing them the other day...
i got sick and tired of taking out all that stuff so i just used vice grips and bent the metal so it would be flush on the underside of the rear deck and screwed the speakers in from the trunk. so they're bottom mounted... now to change rear speakers- just remove subwoofer box, unscrew speakers and unclip wires and swap. it's a lot easier, except that it's harder to screw into the metal from the bottom just because you're working upside down. but once you get the holes done, you're set. just be sure you use a power drill. (i was happy i finally got a chance to use my craftsman 14.4 volt drill- woo hoooooooo...) -clifford
www.clearbrafilms.com |
Why don't you just take a screw driver, and pry off the rear grill, then glue it back on when you're done. about the dremel thing, do you mean you're gonna dremel through the metal of the rear deck? If so, that's gonna be tougher than doing it the regular way.
To cliffud, how do you get the stock speakers out, which are dropped in from the top. With bottom mounted speakers you have gravity working against you, every so often, you're gonna have to go in there and re tighten the screws. Also, did you use dynamat to go between the speaker and the deck?
2003 Nissan Maxima SE Titanium Edition Cattman Catback Exhaust 35% Platinum tint |
#4 | ||
![]() 2)I'm not dremeling out the metal, only the plastic board so that I have direct access to the screws that go down into the metal. The speaker itself sits on top of any other metal that could conceivably be in the way.
It would be hard to dremel out the plastic/fabric without it looking really bad. About the glue thing, no, it wouldn't be messy at all if you were careful. And, unless you plan on swapping out the speakers monthly, glueing in the stock grilles won't pose too much of a problem. I mean, even if you got new speakers every year (which I doubt, unless you're really unlucky)prying ooff the glue won't be that hard... or just use a few drops of silicone... you don't need it to be stuck there forever, just enough for the grill to be held over thespeaker.
#6 | ||
pulled stock speakers out when i pulled out the seats and rear deck. put stuff back in w/o speakers... jumped into trunk and screwed speakers into rear deck. yes- i was working against gravity. every now and then tightening the screws?? never thought about that- haven't done it yet. they sound fine. dynamat: no- i didn't use any dynamat, i probably should though to keep everything nice and tight. doing that won't be a problem though. just jump in the trunk - unscrew speakers- lay the fabric- punch holes in fabric where speaker holes are for ease of screwing back in speakers and then screw speakers back in. i do stuff with my car in spurts... work on it- enjoy it- work on it - enjoy it- work on it- enjoy it... so- right now i'm in the enjoyment phase... considering in the last month, the car has "grown" a CAI and a header. -clifford :smoker:
#7 | |
![]() Join Date: Mar 2001
my infinty perfects fit fine... i guess i was lucky
Craig.... --->redline all the way baby! |
#8 | ||
#9 | |
the most annoying part of the whole task is trying SOOOOOOOOOOO hard to NOT break those plastic button screws in the rear deck... i ALWAYS break one... that- and putting the damn seatbelts back through the holes in the seat bottom so the passengers in the rear don't smack their heads against yours if the AF curse hits.
i hate that part... the part with the rear deck.. eh- i just pull up and wiggle it- it comes loose pretty easily now just because i've done it so many times... -clifford :smoker:
#10 | |
Okay now, just because I'm an ingenious girl who had an awesome idea doesn't mean that you all have to throw hissy fits... :o
Cutting the plastic board isn't that hard. Had to do it last time b/c the friggin old speakers are like crappy 5 1/4" set into a 6 3/4" plate so therefore the holes had to be made bigger. Wimpy little me did it by myself with a carpet cutter blade!!! I also tend to blow out speakers b/c between the new powered head unit, and the stock amps still hooked up there's a lot of juice headin into the speakers. I prefer to just make it less work on myself! I don't want them in the trunk... I'm too careless about tossing things in there.And eventually I'm going to do it... I'll probably also put my neon wire in then, too!
#11 | ||
a gal who's into cars is like... WHOA. -clifford
#12 | |
I dunno
but when I replaced my rear deck in both of my G'z I was able to pry the rear deck up and out of plac with a screwdrive after accidentally snappin all of those annoying screws.
Just be careful that it doesn't rub against the material in the side pillars!
Women call my bedroom the COCKpit! |
#13 | ||
Re: I dunno
Since I'm now running a good deal more power (I now have a powered head unit in addition to the rear amps) to the rear deck, I tend to get a little carried away with the volume at times. I blew out the stock speakers with the stock HU, and now the 652i's are crackling with the DEH6300. At this rate, I think I'll be glad I have a 2-year policy for the speakers!!! I just think that it'll be MUCH easier to replace the speakers with the grilles easily detachable, and having direct access to the speaker itself for removal.
#14 | ||
NICE FEMALE BUTHCER!!!!!!
I never ummmm thought of using one of them anywhere near my car let alone inside it. But to each thier own. LOL!!!!:flash: Oh ya If u buy realy good speakers you wont have to disassemble the G again cuz u wont need to ever replace em??
#15 | ||
Re: NICE FEMALE BUTHCER!!!!!!
