| Non Specific This is the forum to post and generalized racing questions. |
![]() Join Date: Feb 2005
Higher octane?
If you would use a boost or spray at all would you pretty much have to use a higher octane gas?
#2 | ||
just spray, im not sure but I would assume so...Boost definately yes, high compression definately yes
but newer engines can have sensors to gague the amount of knock, so if your running low octane gas the engine will read the higher levels of knocking and retard spark timing and lower amount of fuel injected so you will lose alot of performance...and damage to your engine is a major possibility http://auto.howstuffworks.com/gasoline3.htm this explains octane and knocking
2002 Acura RSX Type-S Quote:
boost in, apex seals out
Re: Higher octane?
knock sucks, to avoid it just do 2 things, dont live in california and buy higher octane gas
RX-7 TII |
#4 | ||
On Fire!
Re: Re: Higher octane?
Our cars run just fine on 91 octane.
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#5 | ||
Automotive love doctor
Re: Re: Re: Higher octane?
Your standards just suck is all. |
AF Vendor
Re: Higher octane?
Pfft, 91? I use 93.
2006 Redline Red Nissan 350Z Base K&N|Falken I am just that JDM tight, yo.
#7 | |
AF - Advisor
![]() Join Date: Mar 2003
Re: Higher octane?
Who wants a car that runs "fine" ... I rather have one that runs great
![]() I run 94 octane at the pump here in PA ![]() Seriously though, cars run best on the lowest octane they can get away with without seeing detonation. Octane is a fuels resistance to blowing up ... you want it to explode! That's what makes power. If it is too ready to explode it will ignite when it shouldn't (knock/detonation) so you need a higher oct. In the 88, the Suburban and Jekyl I run 87 octane. Hyde, with the turbo, gets the best I can find. I am almost always running 110 leaded now.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment |
#8 | ||
240SX Guy
Re: Higher octane?
Fuel octane is as mentioned resistance to the fuel burning. Higher octane fuel burns slower.
I run 9.5:1 CR with 10.5psi of boost on 93 octane everyday. I boost on hot, cold, ect days with no problems. Basically, when you encounter detonation on a certian grade of fuel, you can do these things: 1) Lower the compression ratio 2) Run higher octane fuel 3) Retard timing 4) Cool the intake charge better(AKA alky/water injection) Water/alky injection is a very good solution to running expensive racing gas while still having the power of it. And as jekylandhyde was touching on: Quote:
![]() We over on the KA-T boards tend to stay away from anything past 18:1 dynamic CR on pump gas. We end up running insanely low total timing and it is just not in any way better to run more boost with less timing. And on every grade of fuel, there is a knock limit. Or "the maximum and mean cylinder pressures that can be achieved," SDSEFI Tech: Pushing it too far. Very good read on everything engine destruction related.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
#9 | |
Banned
Re: Higher octane?
ptshhh.... octane= HP =...duh. thats why i run 93 with NAWZ octane booster in my civic dawg.... i even put some pencil lead in there..
#10 | |
On Fire!
Re: Higher octane?
Good post nissanfanatic.
Informative... indeed.
#11 | ||
srs biznis
Shit my secret is out!! |
#12 | ||
240SX Guy
#13 | |
NissanFanatic, You hit the hail right on the head. Very good post, and I'd like to add #5 to it if I may.
For the hard core boost freaks or the ones running big spray numbers, TOLUENE. With the price of gas, toluene is as cheap as gasoline, and a 4:1 mix we'll make about 98 octane gasoline. Go to Sherman Williams paint store and ask for toluene paint thinner. It comes from crude oil and is what's used to boost the octane in gasoline by the oil companys. Also it's legal and will pass fuel tests at the races. |
#14 | ||
Re: Higher octane?
So that's what it's come to for you west coasters eh? Having to make your own fuel cause you got nothin but crap.... |
#15 | ||
Re: Re: Re: Re: Higher octane?
RX-7 TII |
