Old 07-02-2005, 10:03 PM
Dober89 Dober89 is offline
Changes cap, rotor, and wires, now it doesnt start.
I just changed all those parts this morning and I cant get the car to start. Im pretty sure I have the firing order in the right setup, and the rotor and cap only go on one way so those couldnt be misaligned.
Can anyone point me in the right direction?
Old 07-02-2005, 10:21 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Make sure the firing IS in right order and also make sure the cap is on correctly because sometimes it might not be on completely.
Old 07-02-2005, 10:40 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Changes cap, rotor, and wires, now it doesnt start.
if thats all you touched then i am inclined to say you got the firing order incorrect. go back and doubble check.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-02-2005, 10:42 PM
The plugs are in the right order but im not sure if I have the points on the distributor cap right? Like Im not sure if number 1 is where I think it is on the cap...
Old 07-02-2005, 10:54 PM
89IROC&RS's Avatar
best way i know of to fix the problem is to remove the number one spark plug and rotate the engine over by hand and find top dead center by hand, using a finger over the spark plug hole. once you find top dead center on cylender number one install the distributor and wires according to the number one position, put it all back together, fire it up and adjust it with a timing light or vacume guage.
Old 07-03-2005, 12:10 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
umm it should be in the right spot of you didnt turn the distributer at all.was it running before you did that?
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 07-03-2005, 12:15 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Re: Changes cap, rotor, and wires, now it doesnt start.
he changed the cap... so there is a good possibility taht he may have turned it and got the timing all fucked up... the atcual firnig order of a small blcok chevy slips my mind right now... i'm a little tipsy right now... LOL yunno i've alsays been a bud man, but i'd have to say theat german beer is notn all that bad
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 07-03-2005, 02:02 AM
Is eating.
Re: Re: Re: Changes cap, rotor, and wires, now it doesnt start.
Alright Dave, go back into your car to sleep.
Old 07-03-2005, 02:12 AM
Morley Morley is offline
V8?
Starting with the "lug" where you plug the tach, bat and coil wires in. the lug normally points to the driver side, the first treminal fwd of the lug is #1, then keep moving away from the lug and they are 8, 4, 3, 6, 5, 7, 2
Old 07-03-2005, 02:16 AM
Is eating.
Sounds like a 6 but its an 89 so even if it was an RS it might have V8 power.
Old 07-03-2005, 08:26 AM
Originally Posted by Morley
V8?
Its a 5.7L TPI... The lug your talking about, actually points towards the front corner of the passenger side. So basically I guess the cap sits on somewhat of a 45 degree angle. Is #1 right in front of the lug, or is it across on the other side of the cap??
Old 07-03-2005, 02:15 PM
89IROC&RS's Avatar
ill go out and check on my IROC later today
Old 07-03-2005, 03:04 PM
Everything was shifted over one position. I lined the mark on the crank pulley with the timing mark and checked the rotor. It was just behind the position I had #1 on. So I moved all the wires back and it started right up.
Old 07-04-2005, 03:33 PM
89IROC&RS's Avatar
well done, figured it was something that simple.
