p0410
I recently had the problem of p0410. i was told to replace the fuse and blow out the pump to fix the problem. I did so and the service engine light turned off. It was off for about a month or so and then it came back on. I checked the problem with a scan tool and it said the same problem was back. There are two problems with the secondary air injection system just like last time. So should i do the same thing as last time or is there somwthing else i need to do? Thanks
Re: p0410
Make sure the the gas cap is tight, and check the box under the rear driver's side bumper. It probably has water in it. Let it dry out for a day or 2
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
what box are you talking about. I can't seem to find it
Re: p0410
so all i do is open it and let it dry out. Do you think that would trigger a code 0410?
Re: p0410
Water in the evap will definatly set that code (and is the most common problem next to a loose gas cap). Pull it off, have it blown out with an air hose, and let it dry for a day... run the air hose through the hoses that are connected to it as well. Then reset the computer before starting it back up.
now is this connected to the pump located over the skid plate, Should i blow the pump out as well. How do i clear the computer. Do i need to replace the fuse? I think thats what sets the service light to come on. How does the water get in the evap could there be an other problem some where else i should check?
i found the evap canister, now i don't know what to do, I can't get to the hoses and i don't know which ones to disconnect also how do i let it dry i can't find a cap or anything to open.
Re: p0410
Dicsonnect it from the brackets. Mark and remove ALL hoses, go to your local gas station and force air through it. Let it dry out a couple of days.
there is a line that is labeled fuel, is it ok to disconnect this line? Can i drive with this box unhooked? All i have to do is disconnect the hoses to dry out the box, there is no cap to take off?
Re: p0410
no... You cannot drive without it... No cap... Blow it out with air then let it dry for a couple of days
