Go Back   Automotive Forums Car Chat > Ford > Taurus | Taurus Wagon
Old 03-29-2005, 08:38 PM
deserteagle deserteagle is offline
One touch power window relay
Does anyone know how to change this relay?Having problem with my drivers side window.Could possibly be the GEM module but I want to check the least expensive part first.2002 taurus ses.
Old 03-30-2005, 01:08 PM
KimMG KimMG is offline
AF - Advisor
Re: One touch power window relay
What are the symptoms? Correctly diagnosing the problem is the most economical way to go.
Old 03-31-2005, 12:19 PM
Re: Re: One touch power window relay
The drivers side window does not go up or down.I hear a clicking noise from under the dash whenever I push the button.Just got a call from the dlr stating that the initial diagnosis of it being a bad gem module might not be the problem.They want to check it again.So frustrating.
Old 03-31-2005, 02:15 PM
AF - Advisor
Diagnosing an electrical problem requires patienc and a methodical approach.
How I would start:
Make an enlarged copy of the wiring diagram.
Test to see if the motor is getting power and work backwards along the circuit to find the problem.
When one of my power windows stopped working, it turned out to be the motor. I took the motor apart and found a lot of metal filings. Went to a wrecking yard to get a replacement and noticed a lot of the cars were missing the power window motors. (Is this a common problem?)
Replacing the motor took me about an hour.
I hope it goes as easily for you. Good luck.
Old 03-31-2005, 10:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Re: Re: One touch power window relay
If you would like to attempt to diagnose the problem yourself, grab your multimeter and view the schematics at:
http://www.members.aol.com/rod241473...tuff/100-1.jpg
http://www.members.aol.com/rod241473...tuff/100-2.jpg
-Rod
Old 06-13-2005, 12:02 AM
garysc garysc is offline
I'm currently encountering the exact same problem with my '96. What was your final solution? TIA
Gary
