Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 06-05-2005, 08:33 AM
drparkwood drparkwood is offline
Program Key Fob for '00 Odyssey w/pwr doors
Hello,
Just bought a '00 Odyssey and need to program a second remote. Does anyone have the proceedure?
Thanks
Doug
Old 06-05-2005, 11:18 AM
lorunner lorunner is offline
Re: Program Key Fob for '00 Odyssey w/pwr doors
• The system accepts up to three transmitters. The
transmitter codes are stored in a stacking-type
memory. If a fourth transmitter code is programmed,
the code for the first transmitter is erased.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all of the transmitters once you are in the
programming mode.
• You must complete steps 1–6 within 4 seconds of
the previous step to keep the system from exiting the
programming mode.
1. Turn the ignition switch to ON (II).
2. Press the “Lock” or “Unlock” button on one of the
transmitters. (An unprogrammed transmitter can be
used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the
same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the “Lock” or “Unlock” button on the same
transmitter. Make sure the power door locks cycle
to confirm that the system is in programming mode.
7. Within 10 seconds, press the “Lock” or “Unlock”
button on each transmitter. Make sure the power
door locks cycle after you press each transmitter
button to confirm that the system accepted the
transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the
programming mode.
Ordering a Transmitter
Transmitters can be ordered only by authorized Honda
dealers. Order them from American Honda using
normal parts ordering procedures.
Batteries for the Transmitter
The battery number is CR2025. Each transmitter uses
one battery.
Stop asking me about radio codes I cant get them anymore!!!
Old 06-17-2005, 12:38 PM
Thank you!!!
It worked like a charm. Thanks!
