Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-02-2005, 12:44 AM
V T E C H's Avatar
V T E C H V T E C H is offline
COmpression?
Does anyone know what a normal range of pounds of compression for a GSR is??
thanks in advance
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-02-2005, 10:23 AM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
Re: COmpression?
GSR's comp. ratio is supposed to be 10:1
Old 06-02-2005, 08:52 PM
V T E C H's Avatar
Re: COmpression?
how many psi does that equate to
Old 06-03-2005, 04:45 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: COmpression?
if you are not below 175. you are good. also, as long as the results are across the board, you are good.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 06-03-2005, 09:32 AM
Tano016 Tano016 is offline
Re: COmpression?
My gsr has 215 psi all even on 4 cylinders, thats with cold engine. if i add a tablespoon of oil (called a wet test) in each spark plug hole, i get exactly 240 psi, which is normal since part of the oil's job is to seal the clearance between the ring and cuylinder wall. The larger the diffrence between the wet and dry test the more your rings are used up. If any of your cyl are less than 90psi and your car is under guarantee, honda has to re-build your engine underguarantee and they will change all your ringa on all cylinders. I got mine changed at 99000 kms under guarantee.
