I was told that my cv boot was leaking. What does that mean? what can happen if I don't fix it? Is it an easy fix? Thanks in advance. Arnz
If the cvshaft boot is torn, then at this point you're better off replacing the cv joint as once contamination ensues, they go to shit and break...
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
#3 | ||
AF -Advisor
![]() Join Date: Sep 2003
Re: CV boot
People are not made of money and replacing an expensive whole CV assembly because a little grease is coming out of the boot is an unnecessary repair. If there is no noise, repacking and replacing the boot will be the perfect thing to do. CV Boot = $15 CV Joint = $150+ The math is simple.
1995 Factory Blazer Service Manual for sale, PM if interested. |
![]() Join Date: Feb 2005
Re: CV boot
Yep just like rlith said it is easier if you just replace it..It isn't too bad of a job..roughly about an hour..You can get them at autozone for about $175.00 a piece...I think that is what I paid for mine..Just make sure you get the right side you need because there is a difference between the passenger side and the drivers side...
#5 | ||
AF -Advisor
Re: Re: CV boot
They have quick boot repair kits for $15 bucks.
Re: CV boot
Actually around here CV shafts run 65.00 for a complete CV shaft (with a 40 buck core deposit)...Advance auto carries them. Did mine the 1st month I had the truck.
#7 | |
![]() Join Date: Apr 2005
Re: CV boot
Dumb question here. Where is the CV Boot and CV Joint located on a Jimmy?
#8 | ||
Re: Re: CV boot
#9 | |
Re: CV boot
I should have clued in that a 4X4 was being discussed. I have two wheel drive. One less thing I have to worry about. Thanks.
#10 | ||
Re: Re: CV boot
#11 | |
![]() Join Date: Jan 2005
You got choices.
Either remove the axel and replace the boots for about $20 each inner and outer or just the one that's torn. This is a messy job with lots of black goo coming out and even more going back in. Remove the axel and replace it for about $85 + refundable core charge and be done with it. If the tear isn't too bad, get a needle grease fitting and inject grease into the joint every time you change oil. This will sling more grease all over the bottom of your car and your driveway. Remember life is about choices. Personally, I'd just replace the axle or axles, it's not to tough. We did it as part of replacing the ball joints so I don't know if you have to remove the hub or not. If you do check out the ball joints also. See ya 94 |
#12 | ||
AF -Advisor
Re: CV boot
Replace the boot and keep driving and keep the money in your pocket. Only if the CV joint is making noise do you replace it.
#13 | |
Not entirely true... If it is torn it should be replaced. Once it's contaminated with debri you're pretty much hosed.... If it's simply a pin hole leak, yes, I would advocate putting a new boot on as the likelyhood of debri (sand, dirt, et-al) getting in there is pretty low... But if it has more than 1/8th inch gap, it need to be replaced.
#14 | ||
AF -Advisor
Re: CV boot
Comon now, that is way too small to allow any grit in there. An inch or more, yes, but only if it has been like that for a while. Grit cannot force its way through outgoing grease and into the CV joint like that. But if he has a small amount of grease coming out, the chances are that he won't have any grit and dirt coming in. We just need to stop telling people to replace unneeded parts if they are not showing the tell tale signs of a problem. If the CV joint is not clicking when turning, don't replace it. Replace the boot with the new load of CV grease and all will be well. It's like telling someone to replace the engine because the air intake had a small crack in it allowing unfiltered air into the engine. I know its a rather extreme example, but it is just as extreme as replacing a whole CV assembly because of a small tear in a boot. Boot replacements are there for a reason and for this specific application.
#15 | |
Re: CV boot
i drove with a torn cv boot for a month replaced it and still now problems your theory is flawd rlith
