Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 05-09-2005, 10:48 PM   #1
skid2964
what switch and where?
I have a '94 Jeep Cherokee SE ... when I turn on the the ignition many accessories DO NOT work ... the fan motor, the radio, wipers. But the engine cranks and runs fine. When I switch the ignition all the way back to "accessory" ... everything works again! which switch is mal-functioning(exact name so I can go buy one) and where is it located, inside the column? I guess I wouldnt be lucky enough for it to be something under the dash.
skid2964 is offline   Reply With Quote
Old 05-10-2005, 09:10 AM   #2
89ltd
Re: what switch and where?
I believe your jeep still has the ignition switch under the dash on the steering colum. It is activated by a rod from the key cylinder. The switch it self is only about $20, you have to lower the colum to get to it.
89ltd is offline   Reply With Quote
Old 05-10-2005, 05:06 PM   #3
Saudade
Saudade's Avatar
I had to change mine out and I removed the driver's seat to allow for better access.
Saudade is offline   Reply With Quote
