Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 04-07-2005, 04:26 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Leaky Trunk in '96
I'm getting lots of moisture in the driver's side of my trunk.. Any common entry points? It's a '96 EX with a factory Sunroof.
Thanks in advance.
Old 04-07-2005, 06:48 PM
mpumas mpumas is offline
Re: Leaky Trunk in '96
Hondas have problems with the seal between the tail lights and the body. Lift the carpet and see where it is getting in. The tail lights can be resealed. Do both while you are at it. You can use a silcone or urthane to make a new gasket after you take the tail light off the car.
Old 04-07-2005, 07:12 PM
Igovert500's Avatar
Igovert500 Igovert500 is offline
blue + red light magnet
Yep, I'd put my money on the tail lights. Some have said they had their wheel wells rust out, and water get in through there...it never happened to me, but I would think that would be much more noticeable. So yeah, probably the tail lights, if you do a search, you will find this is a very common problem like mpumas said.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Old 04-08-2005, 12:11 AM
Great, thanks for the heads up. My spare tire well is solid, I already checked that.. I'll so a little sealing around the lights, thanks ya'll!
Old 04-08-2005, 10:45 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Use urethane, silicone can cause rusting problems sometimes...
...empty gun rack.
Old 04-08-2005, 10:50 AM
*nod* silicone retains moisture. Thanks for the tip.
Is it just around the mounting holes that it leaks or do I want to seal the heck out of the entire fitting? (making it nearly impossible to remove the fixture in the future?)
Old 04-09-2005, 12:23 PM
Igovert500's Avatar
Pull the light, clean the seal (I don't remember if it is rubber or foam) and put some urethane on the seal.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-04-2005, 02:37 AM
94 Accord 94 Accord is offline
I also heard something about drainage holes for the sunroof but I am not sure where they are. They say you can get leakage if they are clogged. I have been having that same problem.
Old 05-04-2005, 03:50 PM
94accordlx1 94accordlx1 is offline
if water still gets in your trunk after sealing the taillights try installing a new trunk seal. THat happened on my old 90 integra
Old 05-04-2005, 04:08 PM
Igovert500's Avatar
The drains are on each corner of the sunroof...they are simply little holes. If the water is in your trunk, I'd bet the taillights are the culprits, if inside your car, then the sunroof drain is probably clogged
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
