Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-16-2005, 12:27 AM   #1
GQsinceBirth
1999.5 jetta issues..
ok.. well this time it sounds like its the tranny..
my 2.0 is a 5 speed.. everytime i shift from first to second gear or even second to third.. it sounds like theres a grinding noise between 4 and 5,000 rpms?.. like something is loose?.. idk.. what is that?.. im not grinding gears.. but it really sounds like something is loose down there.. other than that the car shifts okay.. except for a little rough jump from first into second..
not only that, but.. whenever im in park.. there is a ticking noise coming from the engine... (tick tick tick tick tick tick tick tick??).. never goes away.. its pretty much there all the time.. someone pleaseeee helppp
GQsinceBirth is offline   Reply With Quote
Old 02-16-2005, 05:20 PM   #2
boschmann
Re: 1999.5 jetta issues..
Are you sure it's not an exhaust rattle or something. Is the ticking from under the valve cover.
boschmann is offline   Reply With Quote
Old 02-17-2005, 11:30 AM   #3
GQsinceBirth
im positive.. i just found out the ticking was actually the valves.. and that im paranoid, so they sound louder to me than to anyone else.. but are actually normal.. lol.. but the grinding im gettin in between 4000 and 5000 rpms can be heard by anyone, and does not sound good at all.. im 100% sure its originating from the tranny.. i just dont know what it is.. what do you think it could be?
Old 02-17-2005, 11:35 AM   #4
MikeLee2484
is the noise a grinding or a rattle? i had a rattling noise that was a broken spring in the pressure plate in the clutch...i havent gotten it fixed yet because it hasnt had any real effect...thats what the machanic told me it was anyway
MikeLee2484 is offline   Reply With Quote
Old 02-17-2005, 11:44 AM   #5
GQsinceBirth
now that i think about it.. it could be a really loud rattle.. i get it in between 4000 and 5000 rpms.. right before i shift into next gear.. do u experience the same?
Old 02-17-2005, 08:53 PM   #6
boschmann
It's unusual for a trans to have a problem only at a certain engine rpm. Flywheel, clutch & rattles would be more likely.
Old 02-21-2005, 02:53 PM   #7
dannyh
I have 1999 Jetta as well. It is the old body style though. I have an exhaust rattle when I am about to shift. I have had it for quite a while. I might be the same problem that you are having. The shield that attaches to the bottom of the car, above the muffler is what rattles. Even though it is connected right, it still rattles. It is just the way VW made it. I am going to try tu use some high temp silicone to stick it to the bottom of the car. I'll let you know what happens.
dannyh is offline   Reply With Quote
Old 04-26-2005, 07:50 PM   #8
WannaR32
i had a similar problem with my '99 jetta... turned out to be the catalytic converter... and if you're under 80k miles...you can get it done for free...check it out at a dealer
WannaR32 is offline   Reply With Quote
