Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 05-26-2005, 10:19 PM
yomamasezhi21 yomamasezhi21 is offline
Headlight on all the time
I have a 2003 Chevy Tracker zr2. The headlights stay on all the damn time and it is annoying. Does anyone know how to turn this off or if it is even possible. Thank you
Old 05-27-2005, 05:52 AM
Phu's Avatar
Phu Phu is offline
Send a message via ICQ to Phu Send a message via AIM to Phu Send a message via MSN to Phu Send a message via Yahoo to Phu
Re: Headlight on all the time
Those are called Daytime Running Lights (DRL's). You should be able to pull the parking brake one click up to turn them off without actually applying the parking brake.
How are the DRLs annoying? You can't see them. It's a safety feature to make yourself more noticeable to other motorists. The only real reason to disable the DRLs is so you can 'black out', but even then, unless your in law enforcement/security/etc, why would you need to black out?
Old 06-01-2005, 01:05 PM
ggcatt ggcatt is offline
The other way to disable the DRL's is to move the ignition switch back slightly, such that the engine and accessories continue to run, but the DRL's turn off. I find this better that lifting the parking brake lever one notch at a drive through or other waiting spot. I can continue to move without disengaging the brake. On the highway I always keep the DRL's on.
