Go Back   Automotive Forums .com Car Chat > Engineering/Technical > Tires and Wheels
Old 07-19-2001, 11:59 AM   #1
Neil82
Neil82's Avatar
Send a message via ICQ to Neil82
17" alloys......215/45 or 215/40's ?
Hi I was wondering if one of you could help me, im just about to order a set of 17" alloy wheels for my P11 Primera 2.0 Sri 5 door hatchback (UK Car). I first thought about getting 215/40 17" tires becuase that wouldnt exceed the radius of my existing tyres (195/60 15"). However after reading some posts on this forum im not sure, the car will NOT be lowered and people have told me it will look stupid with the 215/40 tires. Now I am thinking about 215/45 17" tires, BUT this would increase the size of the wheels over the existing 195/60's, the reason this worries me is because after inspecting under the front arches of my car I found a bar (not very technical i know) just above the tire and if the size of the wheel were to exceed the factory tires i beleive it may rub on this bar???? will it??
Also could someone tell me whether i need 7" or 7.5" wheels? and what the offset of these wheels should be if using 215/45 17" tires. Any photos of g20/primeras with 17" alloys and stock suspension would help me alot.
Many thanks
Neil
Scotland
wheel sizes
Henry, the grille on the below Primera is the one i can swap you for your PI lowering springs, you want it?
Neil82 is offline   Reply With Quote
Old 07-19-2001, 01:06 PM   #2
kenchan
kenchan's Avatar
you'll still look stupid with 215/45's if you don't lower your car. get a 16 inch wheel with 205/55/16 if you're not planning to lower it.
kenchan is offline   Reply With Quote
Old 07-19-2001, 01:33 PM   #3
Neil82
Neil82's Avatar
My car comes with standard stiffened/lowered suspension as well as a front strut brace so I wouldnt like to risk spoiling the handling by lowering it any further. Does anyone else think i should get 205/55 16" instead of 215/45 17"?
Old 07-19-2001, 02:02 PM   #4
Mythos
Mythos's Avatar
Send a message via AIM to Mythos
215/45 will reduce the wheelwell gap more than the 215/40, but, there will still be some gap and with 215/45 your car's vertical height will increase slightly.
Mythos is offline   Reply With Quote
Old 07-19-2001, 02:03 PM   #5
kenchan
kenchan's Avatar
if you car came lowered by about 1.5inches or 40-45mm, then go for the 17's. it's a waste to get 16's if your car is lowered. handling wise, you'll notice a lot more nimble handling, less bounce from the rubber and a stiffer ride. which is allll GOOD.
:alien: :silly2:
Old 07-19-2001, 05:47 PM   #6
primera man
"P-Man"
primera man's Avatar
Go with the 215/45/17 as they will fill the gap a bit more.
If what you say is correct about it already 1.5" lower, you should end up with a good ride along with a good look
View All My Models Here.
primera man is offline   Reply With Quote
Old 04-20-2004, 08:53 PM   #7
Dsilver
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Re: 17" alloys......215/45 or 215/40's ?
That P-Ride is pretty cool, who makes that?? and what are the specs on it.
Dsilver is offline   Reply With Quote
HELP: 16" alloy wheels VS 17" alloy wheels traders008 Tires and Wheels 1 11-13-2005 01:25 AM
215/45/17 rubbing w/no drop and w/drop?? ephyouckay Accord/TSX/Accord Hybrid 3 06-23-2004 11:29 AM
215/45/17? config Integra 7 07-26-2003 05:20 PM
FS: TRM(Kosei) Snipers 17x7 with 215/45/17 kenchan Classifieds 1 11-10-2002 12:57 PM
